Hi folks,
I have a Sony VPH-1272Q projector and I want to run it at 1080i (I understood that it will give much better results than 720p).
The question now, is which refresh rates does my projector's bandwidth is capable of ?
As far as I understood from this thread, if my movie is 1080i with AR of 2.35 then I'm able to crop the black bars and save bandwidth because actually, the resolution that my HTPC send to the projector is 817i.
So which refresh rate should I try for the following in 1080i ?:
HD-DVD / Blu-ray Disc of 2.35 AR movies
HD-DVD / Blu-ray Disc of non 2.35 AR movies
HDTV broadcasts at 25fps and 30fps
PAL DVDs
NTSC DVDs
PAL DVDs
NTSC DVDs
