Is anybody aware of any low-profile DVI-I cables, couplers, right angle adapters, etc, that have a short plug length on the male side of the cable? My HTPC juts out about 3/4" over the front edge of the shelf due to needing 2" of space for the plug of the DVI-I Cable connected at the back (2" from the front of the plug connector to the back of the thumbscrews). When I ordered the HTPC case I failed to consider leaving space for the plug in my measurements. A low profile male plug (1"), low profile right angle adapter, or whatever to get that inch back would be perfect, if such a thing exists. Cutting a hole in the shelf unit to make space is not an option.
-db
-db
