AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Pioneer 816 -- worthwhile SQ upgrade over Onkyo 570 HiTB receiver?
post #1 of 6
Anyone have any opinion on whether the Pioneer would be a noticeable upgrade in SQ over my Onkyo? I decided to pass over HDMI altogether for a while until I can afford something really nice, so I'm just looking for a "temporary" (2 years or so) $200-ish receiver that has at least 3 component inputs and sounds nice. I'd appreciate any other suggestions as well. Or should I not even bother with an incremental upgrade and just save up? Thanks!
post #2 of 6
I was very much in the same situation, wanting to buy a receiver that did lots of things acceptably well but fit within a tight budget. I'm not familiar with the Onkyo you mentioned, but the Pioneer 816 sounds like a strong alternative. It gets good reviews in its price range. If you do want HDMI switching (not upconversion, but switching) without leaving that general price range, I have been happy with the Sony STR-DG800, which you can get for under $300 if you hunt around.
post #3 of 6
Thanks for the feedback. I'll look into that Sony. I also spotted an open-box Denon 687 for $299 at Circuit City...
post #4 of 6
Originally Posted by Mike_NW View Post
I If you do want HDMI switching (not upconversion, but switching) without leaving that general price range, I have been happy with the Sony STR-DG800, which you can get for under $300 if you hunt around.
Mike,
Im not sure what the difference is between HDMI Switching vs upconversion? Is there a description of what one does vs the other?
Rich
post #5 of 6
HDMI upconversion will send all sources hooked up to your receiver (composite, S-video, component) to your display via a single HDMI output. HDMI switching will only send other HDMI sources to your display.
Okay, I've changed my mind again. Yamaha 659 at J&R for $325 tax included, possibly slightly less if I haggle more, any thoughts?
post #6 of 6
I bought the 816 as a replacement for my Outlaw Audio 1050 and I had to return it. It sounded distinctly worse to me. I can't say if thats a testament to the Outlaw's quality or the 816's lack of quality, though.
But given the lower price, I guess I shouldn't be surprised.
