AVS › AVS Forum › Audio › DIY Speakers and Subs › couple newb questions - reverse polarity to bridge crown xls 402 and hig pass filter?
post #1 of 3
I'd like to use my spare crown xls 402 amp. It's bridgeable but since it's the older model and doesn't have a simple switch to switch it to bridge mono mode, I have to use a y splitter and reverse the polarity into input 2. Where or how can I reverse the polarity on 3 pin XLR cable? I believe pin 1 is cold, pin 2 is hot, pin 3 is shield.
1. Can I just cut it open and reverse the wires to pin 1 and 2 and leave pin 3 alone?
2. Also, when I model in WIN ISD Pro of a TC db 500 at 3.5 ft cubed and 23 hz, the cone excursion goes way past 20 mm below 19 hz. Do I need to implement a high pass filter? When ever I do a sealed config some drivers go way up to 50 mm of excursion feeding it 1000 watts (this includes the TC3000) Am I modeling this wrong?
3. If I go sealed, what's the most I can bump up 20 hz using a BFD. Obviously I can stack the filters, but what's overkill and not safe here?
Thomas
post #2 of 3
Page 9 on how to make the custom Y adapter with inverted signal on channel 2.
http://www.crownaudio.com/pdf/legacy/133465-6.pdf
XLR pin out;
http://www.faqs.org/faqs/theatre/sta...ection-25.html
You are swapping pin 2 and 3.
Pin 1 stays the same.
You can do this swap inside the amp and just use a generic Y adapter, but
it's probably better to make the special Y adapter unless you found an off the shelf one that does signal swapping.
Ported boxes pushed to their performance limit should have a high pass filter.
You can operate your subwoofer without one but you have to keep an eye
on the woofer when you crank it up.
post #3 of 3
I don't have my XLR cables in front of me, but are the pins labeled?
Thomas
