Originally Posted by
1 Infinite LoopÂ
Too bad this doesn't work any more.
Tried to run the DirectX patch, no luck.
Should have been written for the Mac. That way it would actually work.
MitchSchaftÂ
I got it to work by right clicking on first102.exe, going to the compatability tab and choosing windows2000. Now it loads up fine for some reason. Wish the author didnt fall off the map
I'm running XP sp3.
I'm trying to get the 1.02c version to run on my computer, I kept getting this error "missing D3DX9_32.DLL", so afte reading here
http://pcsupport.about.com/od/fixtheproblem/ht/restoredx9dll.htm
downloading the below now.
http://www.microsoft.com/en-us/download/details.aspx?id=10990
The December 2006 SDK includes D3DX9_32.DLL. This DLL includes the Direct3D 10 HLSL compiler enabled for Direct3D 9 targets (shader models 2.0 and later). The new compiler has no support for 1.x pixel shader targets. This new compiler is the default for Direct3D 9. As a result, all developers are encouraged to author their shaders in HLSL and use shader models 2.0 and higher. The legacy compiler is available using the /LD switch.
