AVS › AVS Forum › Audio › Receivers, Amps, and Processors › hdmi 1.3 question w/ blu ray player question
post #1 of 6
with the future release of blu ray players that have hdmi 1.3 that decode dts-hd, dolby digital plus, true dolby hd, etc. will i still need hdmi 1.3 receiver to take advantage of the full capabilities? or will the blu ray player be suffieceint? basically what im asking is if my onkyo receiver will pass the signal through it or will i have to upgrade to a 1.3 receiver?
post #2 of 6
Onkyo receiver models TX-SR674 and higher will play lpcm ok.
post #3 of 6
What about the 604? Wll that still play LPCM ok?
post #4 of 6
If the 674 does it ok then yes the 604 will play LPCM ok. They are identical in this regard.
post #5 of 6
i have the onkyo tx-ds787 with no hdmi connection. im using fiberoptic cable for sound right now. so does that mean i need a receiver with hdmi connections?
post #6 of 6
my onkyo is older it doesnt have any hdmi input. the model number is tx-ds787. so does that mean i need a receiver with hdmi connections? right now im using a fiber optic cable for sound
No, you cannot experience the new audio formats with legacy digital connections like digital optical or coax.
If your Onkyo has a 5.1 analog input, you can use that. But you've got to use HDMI or 5.1 analog, because the 10-year-old optical and coax connections -- as implemented -- don't have the bandwidth to support the new and improved audio on Blu-ray and HD-DVD.
Note you can still use your old receiver, as all disks include Dolby Digital 5.1, DTS 5.1, or LPCM 2.0 stereo for backward compatibility with older hardware. However, in order to experience the new and improved Dolby Digital Plus, Dolby TrueHD, DTS-HD, and/or uncompressed audio, you need either a HDMI receiver, or a receiver with 5.1 analog audio input.
