AVS › AVS Forum › Video Components › Cable, Digital Cable - Non-HDTV › On Demand movie formats
post #1 of 5
Purchased the Wide version of "The Departed" over the weekend and I'm not sure what I was supposed to get. I have a 16:9 TV (SONY 46E2000) and I have my cable box set for 16:9 output. However, the picture I got had black bars on top and bottom and also had the pillar bars left and right that you get with 4:3 programming. This is with Time Warner cable in NY/NJ. Upon further research I found that this movie is filmed at 2.40 aspect ratio, so I guess that accounts for the black bars on top and bottom. But why did I get the pillar bars as well? Shouldn't the Wide version have filled my screen horizontally? Any insight?
post #2 of 5
Yes It should have... Do other On Demand movies come in the same way?
for me-- the bars at the top and bottom sometimes happen, but I never get the pillar bars on the left and right with movies on demand.
On my television I can change the screen size which fixes lines at the top and bottom, but I would call time warner about it if you were unhappy with the movie.
btw the departed was awesome
post #3 of 5
You purchased the widescreen version of the film which preserved the OAR, but in a 4:3 signal format, akin to a widescreen VHS, not an "anamorphic" 16:9 version. You would have had to manipulate the viewing options of your TV (Zoom, Stretch, etc.) to fill the screen horizontially.
post #4 of 5
Thanks for the responses. I did call TW but the person I got was of no help. After some more research I've found that BTT917 has it covered. On my cable system all On Demand is broadcast in SD (4:3), so movies that have a wide version will have the black bars in a 4:3 window, and movies that don't specify are in the pan & scan chopped version. I will try another wide version and test out the zoom modes.
And yes, The Departed WAS awesome....
post #5 of 5
You'd be better off renting a DVD. You're going to lose a ton of resolution zooming an SD signal. Just my $.02.
  Back to Forum: Cable, Digital Cable - Non-HDTV
