AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Trouble with new Panasonic TH-42P600U
post #1 of 9
Received TV Monday morning (3/19/07).
Set it up early that evening on the supplied stand.
Hooked up all cables & set worked great.
After dinner hung the set on the wall mount I installed on Saturday.
Set worked fine & watched for about 2 1/2 hours.
Came home today (3/20/07), set woked fine for about an hour then a bunch of flashing colors, then nothing.
Pulled power cord & reconnected.
Nothing, the red power light blinks 7 times, pauses, 7 times and so on.
Called Panasonic & they are supposed to call tomorrow to send a tech to the house.
I'll let you know how it all works out.
bbg
(I wasn't sure if this belongs in the issues thread)
post #2 of 9
If possible, I'd recommend returning your PDP for a replacement or a refund. I'm not a big advocate of fixing something when it is sold to me as brand new.
post #3 of 9
I feel the same way, I really do not want to start off like this.
bbg
post #4 of 9
Life's too short, bbg - have them replace it.
post #5 of 9
Agree - if it is within the return period just swap it out, preferably for one with a serial number not to close to the one you have, or a different production date.
post #6 of 9
Panasonic called Wednesday morning & set up Thursday appointment.
Repair tech came at 2:30, changed circuit board, done by 3:00.
All looks perfect.
Was worried about repair on new set so we will see if anything else crops up.
Tech said I should not have any other trouble.
bbg
post #7 of 9
Wow, sounds like they have good service.
post #8 of 9
Bruzzi (OP of Plasma FAQ sticky thread) has some information on Panasonic's blinking light error codes if you're interested. He may be able to tell you what the 7 blinks was all about if you post in his thread. I think it usually it identifies which board is bad.
post #9 of 9
I will do that. thanks
