True, but his prisms are just 70mm high. Mine are 140mm high. Both are BK7 with an optic coating...
And now we can get prisms coated in US for affordable cost.
I wonder what is the major difference between the prisms that
we can get in US for $50 a piece to the custom cut prisms or the
prisms used in riduculously priced commercial lens, other than
the fact that they are trophies.
I guess the commercial lenses are expensive just because of monopoly. If there are more manufacturers obviously the price will drop. The prism prices arent going to go up. After all it is a piece of glass and they are used for variousl other
applications including trophies.
With the pro lenses, your paying for a much finer finish. Whilst the trophies look smooth to the eye, under magnification they are not that smooth. True optic polishing takes time and costs money - time is money...
Moreover when I have a projector like IN72 which costs $599 or less
I wouldnt want to spend a lot of money for the lens.
These group buy options for a couple of hundred bucks is good enough.
Like I said I tried the $8 ebay prisms and the picture was fine. I am sure
the US prisms (this thread) or sam's prisms would be just fine especially as they are coated.
Hope it works out for you...
Mark
