AVS › AVS Forum › Audio › DIY Speakers and Subs › Newbie Looking for Info
post #1 of 29
I have Athena speakers. Fronts are F2.2s, center is a B2.2, and rears are B2.2s.
My problem is my center is too weak, and the center you can buy from Athena the C1.2 is too weak as well.
I have a pair of B2.2s that are extra, and would like to build a center speaker out of the pair if possible.
How would I start, I don't see any stickies about basic setup or anything.
The C1.2 has 2 5.5" woofers and a 1" tweeter.
My pair of B2.2 would be 2 6.5" woofers with a 1" tweeter.
I just need some info on the electronics/boards I might need, and enslosure construction.
post #2 of 29
You also need information/hardware/software on determining the Theile/Small parameters of the drivers you have. The hardware and software to build the appropriate cross-over and finally the experience to tweak the results by ear. Nothing about building a speaker the correct way is "basic". You can take shortcuts and use pre-built crossovers, etc but you will not be happy with the sound compared to your current speakers.
What makes the center channels from Athena "weak"? Have you calibrated your system so that all speakers are at the same level? Have you plotted your system's frequency response to deterimine if you have some room induced issues? There's a lot of work you should do before you start replacing equipment.
-Robert
post #3 of 29
Uh....stick with the single B2.2
I don't know what you mean by weak, exactly. If you have the levels set properly, it should sound OK. Either stick with it or get a single F2.2 for center duty (which would actually be more ideal).
post #4 of 29
I have calibrated all the speakers to the same level, but not plotted any frequency response, how would I go about doing that?
Even at +10 the voices in movies are not clear/loud enough in many movies.
I have a spare F1.2 but height is my issue, my screen is only 15" or so off the ground, and I was told tilting the speaker horizontally would not be good.
post #5 of 29
What did you use? Internal tones and your ears? Calibration DVD and an SPL meter?
TrueRTA sofware, a PC and a calibrated mic. You may want to just work on the calibration before attempting this.
Not good for the speaker or not good for the sound quality? It won't hurt the speaker and your center channel output is already not optimal. A quick test will only take a few minutes.
-Robert
post #6 of 29
If your speakers are properly level matched and you're still experiencing problems, just get all new sepakers. Doing some hack job with two B2.2's will not help the matter.
post #7 of 29
everyone has already explained that this won't be an easy undertaking...someone hacked something together here:
http://gallery.avsforum.com/showphoto.php?photo=11906
but I doubt that was a proven out design...just as I said in my comment there...the spacing between the drivers is off, etc etc...
if I were in your shoes, I'd start auditioning a larger or three way center that is close to the timbre of the rest of the athena line.
post #8 of 29
I have calibrated them using test tones and an SPL meter.
I won't be investing in new speakers, that is out of the question due to budget.
How do I find a better center that is close in timbre to the Athena line?
post #9 of 29
I honestly wouldn't be as concerned about "timbre matching" as I would be getting the best center for your budget...but maybe I am just crazy. Now, if you had really nice fronts, it might be another story.
post #10 of 29
That is a cool link about the custom center, if I could do that and have it work that would be a fun project, as I like DIY stuff and building things.
Any recommendations for a good "value" center? Something that would match up ok to my F2.2s.
post #11 of 29
What is your budget?
post #12 of 29
there's nothing that says he can't do both...if he plans on keeping the Athena's, which are pretty fine speakers, for a while then he might as well do it right the first time.
arbitrarily buying a center just because it fit his budget could just lead to more disappointments when there are pans across the front stage, and there's a change in timbre...clearly he's already concerned about his centers dialogue intelligibility, so one could deduct that he might also care whether or not the pans are as seamless as possible.
post #13 of 29
this is exactly what i would do. I doubt you'll find a center that's much better than this situation unless you want to spend more bucks on a three way.
post #14 of 29
Of course, but his concern for clear and intelligble dialog seems to be more serious than worrying about timbre matching.
But he can always just audition some stuff in his setup to determine what fits and what doesn't, as far as the total packacge is concerned.
Exactly, but that is what puzzles me. He says he level matched everything, but apparently even with the center trim set to +10, the dialog is still unclear.
post #15 of 29
Isn't it possible to build a proper center out of Athena bookshelf speakers?
I actually have 4 spare B2.2s and 2 B1.2s.
This being the DIY speaker forum, I was looking for more options than keeping my current center, or buying a new one.
Is it not possible to build a proper center? If it is not, why does this forum exist?
post #16 of 29
The center speaker is level matched at +6 using the test tones from my receiver.
But when I play a movie, I find the voices getting drowned out, even when I adjust it up to +10.
post #17 of 29
Oh, if you want to build a center from scratch, that could certainly be arranged.
But I don't think anyone here in their right mind would recommend a frankenstein approach using your spare B2.2s or B1.2's. Now, if you sold those and spent the funds on parts for a new one, you'd be in business.
Do you have any pictures of your front soundstage?
post #18 of 29
I have to do up a diagram and some pictures yet, I dont have anything available right now.
I just thought using the woofers from the B2.2s would keep the sound more consistant than buying different ones?
post #19 of 29
Do you want consisently unintelligble and unclear dialog?
post #20 of 29
Have you been through all the setup options on your DVD player.
A friend of mine almost wept with joy when we discovered that his player had a "dialog level" setting buried in there......
post #21 of 29
Good call Collo. I was thinking that there must be something else going on. Any half-decent MT shouldn't sound so bad for center use.
post #22 of 29
I am playing everything through my computer, so I will check the dvd player software for any settings like that. I am using PowerDVD.
Wild, no I want nice clear voices from the center channel. I just though moving up to double the woofers would provide the mmmph that might be enough to fix it.
What parts would you recommend I buy for a 3-way center? Vendors/prices would be helpfull too.
post #23 of 29
If you want to build a great center--the Audax Center channel is fantastic...
Not sure how the timbre would line up with what you have...
http://www.madisound.com/audaxhometheater.html
Looks like the drivers are getting harder to find, they have all the drivers at Parts Express for around $110.... I don't know if Madisound still carries the drivers or not, maybe you could get them to sell you some crossovers, or you can get the schematic and make your own if you know how.
Cheers
Mike
post #24 of 29
I don't know what a crossover is, but I love to learn how to build stuff. I know what I will be researching in my spare time now!
I just ordered some Aura Pro shakers from Parts Express, I am waiting to see how smoothly the border crossing is, if it is smooth then I would consider ordering more stuff from them.
post #25 of 29
You should definitely check out this design: http://www.htguide.com/forum/showthread.php4?t=15323
And the others there. I know that Kingpin (who is a member here as well) has had great experiences with PartsExpress and he lives in Canada.
post #26 of 29
Most receiver test tones are not accurate. Get a calibration DVD and try it again.
Just the most important part of a speaker. You can buy the most expensive, best sounding drivers in the world and come out with a horrible sounding speaker if the crossover isn't designed correctly.
-Robert
post #27 of 29
Thanks for the link Wild.
I will do some research on crossovers today.
post #28 of 29
I have a Bose Acoustimass 10 with the center cube being used as my rear center. For the front center, I' m using a Polk CS400i. My guess is that is does not timbre match at all. Conversely, it sounds great! This speaker is so clear and can handle any bass thrown at it.
I've been contemplating getting a VCS 10 Bose Center speaker to match timbre of my cubes but the reviews of the Bose VCS 10 are so bad. The reviews of my Polk are so much better.
Is timbre matching all that it is cracked up to be? Is it better to timbre match even if it means downgrading to a lower quality speaker?
post #29 of 29
Apparently I am one of the few that believes it isn't better to timbre match instead of going with a better quality center.
Now, if the quality difference isn't that significant, it is one thing..but in your case, it is.
