AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › I'm about to order the westinghouse 1080p!! any reason NOT to?
post #1 of 36
the LVW-37W3 to be exact!! going to get it from newegg and will be using it for SD tv and xbox 360.. what do you guys think? any better options out there?
post #2 of 36
Westinghouse is an excellent choice. In reality I feel the actual TFT screen and quality of the inputs is far superior to the traditional name brands out there. Makes it a top choice for game enthusiasts.
post #3 of 36
Im really not a fan of how the Westinghouses always appear cold to me. At least, colder than other models from first rate manufacturers ike Sony/Samsung
post #4 of 36
I got mine from mwave. Shipping was ~$50 and got it in 3 days. Had to call back and verify order, though, but I passed on newegg because I saw some posts mentioning longer shipping delays.
I'm using my 37W3 as a PC monitor from 30" away and the picture is very sharp - I plan to hook up an xbox 360 as well. I read SD on this set may not look that great - I haven't tried it. I also notice a bit of backlight leaking through on each side (primarily right side) when there's a black background displayed but this appears to be the result of sitting so close to the display - when I backup 6+ feet, it basically goes away.
post #5 of 36
I am also considering a Westinghouse (47", 1080P). I am having a very difficult time choosing a TV because I cannot see half of them. I've checked all the stores I could think of in my area for a lvm-47w1 that might be on display, but none have them. There is a Best Buy close by that has them in stock, but not on display. I am reluctant to purchase something so expensive without seeing one.
post #6 of 36
I have been repeatedly looking at various LCD monitors and comparing their conector sets and known limitations, and I always come back to the Westinghouse LVM-42W2. I figure, every display out there has limitations (clouding, banding, overscan, black levels, whatever), but I can excuse a lot more on a low-priced display like a Westinghouse than I could on a Sony or Sharp, even if I wanted to spend that kind of money (which I don't).
Yes, there are new Westinghouse TVs coming out with built-in ATSC tuners, but the "W1-W3 series" is a known quantity at this time, and if a whole different set of issues arise with the "TX series", it may be too late to get one of the current monitors (with a factory warranty). For what I want (a display for casual watching, but at the highest resolution available, and with plenty of input options and adjustments), the 42W2 should be about ideal.
In my case, I live in California, so worst case if I have to send the monitor off to Westinghouse for warranty repair, at least they are in the same state.
post #7 of 36
The "TX" series uses the same generation panel as the newest w4207 model, except in 1080p resolution. So you can expect better color uniformity and grayscale tracking over the old "W" series. The current W4207 is superior to the 42w2 in all aspects except resolution.
post #8 of 36
Best buy does have a no questions asked 30 day return policy.
The Westy's are worth the money. And come with a superior screen and input jack pack.
post #9 of 36
Has there been any pricing info released about the TX series? I was also thinking about getting the 42W2 but I figured I'd wait around till the TX series comes out in hopes of a price drop. I don't want to risk not being able to get one though, so maybe I shouldn't wait?
post #10 of 36
That's a very fair comment. I know that one of the first things I did with my 37w3 was calibrate the screen, starting with changing it to the warm (1) setting helped a bit. I've read other comments on it's ability to display greens properly, but the 37w3's colour accuracy has never bothered me and I think it's particularly accurate with flesh tones.
For what it's worth I love mine, especially the picture beside picture option to catch a sports game while I'm playing something on my PC. Though when just watching SD, even digital SD, I prefer to sit at least 6-8 feet away.
post #11 of 36
$1999 MSRP for the 42" and $2499 for the 47". The 52" is TBD. I would expect street prices to fall about where the current models are within a month. They are improved panels with cold cathode backlighting now so it is probably worth the 1-2 month wait for them.
post #12 of 36
Dont waste your money on a 42w2. Either look at the w4207 or wait for the new TX series to come out. The w4207 and TX monitors all use the new gen. LCD panel. The 42w2 uses the last generation panel.
post #13 of 36
And you state this with what kind of experience on HDTV's? And is this after your display "calibration"?
Or are you just making a completely pointless observation from store models which have most likely NOT been properly calibrated to an environment which is alot different from your own home?
post #14 of 36
I don't have a Westy, but it seems like the Westy is really the only set that you hear mostly positive comments on. Every other brand in this forum has more bashing comments than positive comments. Westy is the exception, more positives than negatives.
Many people feel the Westy is the best bang for the buck.
post #15 of 36
First, there are no "generations" of panels. There's nothing revolutionary about the panels used in the TX series or the w4207.
Second, your earlier comments about the w4207 are not borne out in tests. The panel in the w4207 does not have superior uniformity to the 42w2 according to any test I've seen.
The TX series *may* have a better overall picture than the 42w2, but if so, it's not going to be by much and will likely not have much to do with the panel if so.
post #16 of 36
Actually there ARE panel generations, just like there are models of cars or anything else you buy.
The w4207 and TX series uses Chi Mei Optoelectronics 5th gen. LCD flat panel design. The w1,w2,w3 series monitors uses their 4th gen. panel.
And ummm, yes, color,contrast,grayscale tracking, black level and detail, even viewing angle have all been improved upon.
post #17 of 36
just copied you dude, I shall hold you responsible !!!!
.....just kidding
I'll get it next week.
And you hakaveli ?!?! have you made your move yet ?
post #18 of 36
just ordered mine from the egg cant wait til it gets here
post #19 of 36
It comes from my experience with a lot of Westinghouse LCDs, their HDTVs and desktop computer LCDs. Their backlights just seem to have a bias towards cold color. I know it won't bother the vast majority of people, but as a photographer by trade, color balance really drives me nuts. And it bothers me with almost every LCD, because I can't stand the flourescent look. However, some manufacturers have a better handle on the gamut of their backlights, and I can't wait for LED backlit LCDs with fully adjustable temperature
post #20 of 36
.....just kidding
WHAT A F*****G BAD IDEA I HAD !!!!!
I just cancelled the order from these complete losers. They called me twice and still were unable to process the order for idiotic reasons. Imbeciles !!!
Ok, I am done now - sorry dudes I just can't stand places that should facilitate transactions and instead waste my much more valuable time. That place sux. I should have stayed with newegg where I originally was going to place my order.
Phone calls and stuff, I mean that is pre-historical !!!
I will still get it next week.
post #21 of 36
If this is concerning the backlight. Its best left to 0 setting anyway. I only run my backlight at 20 when there is an abundance of room lighting. But regardless if its at 0 or 20 WARM prest is still the closest to the 6500k standard.
post #22 of 36
congrats dude. newegg is a good place I must say, never had a prob with them and no phone calls
post #23 of 36
i just hope it doesnt get damaged in shipping!!
post #24 of 36
right ... do we have to do those things like making sure the box is not damaged before we accept delivery ??
post #25 of 36
Well, the only objection I would have is, considering what you are using it for, and the size of the tv, why would you need it to be 1080p.
Save the money and get a larger, better 720p set for the same amount.
post #26 of 36
well i could use the 1080p because the 360 supports 1080p and games will start to come in 1080p. also, i may want to invest in an hd-dvd sometime in the future. Or I'll have the TV for years and in about 10 years 1080p will be the new standard
post #27 of 36
hey i just ordered the 37w3 this morning from newegg, I got tracking number and checked right now and it says it is scheduled to be delivered tomorrow!!! can this be too good to be true??
Status: Exception - On Time
See description below
Scheduled Delivery: 03/23/2007
Shipped or Billed on: 03/22/2007
Service Type: GROUND
Weight: 53.00 Lbs
Package Progress
Location Date Local Time Description
BALDWIN PARK,
CA, US 03/22/2007 7:21 P.M. FORWARDED TO THE FACILITY IN THE DESTINATION CITY
US 03/22/2007 7:01 P.M. BILLING INFORMATION RECEIVED
post #28 of 36
I ordered my LVM-42W2 today. The dealer will not have them until after 4/1, so I have a couple of long weeks to wait, but that's a lot less than the 3 months I have spent reading and comparing, and ordering/returning a Sceptre 42" 1080p LCD TV.
post #29 of 36
and btw, mine is being delivered tomorrow.
hakaveli, enjoying yours ?
post #30 of 36
Seems like a trend is going on here. My 37w3 is scheduled to arrive today via UPS, and I ordered from Newegg, What concerns me is the policy if box is damaged to return it for refund. Knowing how I've received packages from UPS many times with damage, I shudder to think what that box may look like. I seem to be near the last to get delivery because of the route in my area, which means my shipments most likely get shoved around quite a bit.
