AVS › AVS Forum › Gaming & Content Streaming › ReplayTV & Showstopper PVRs › Can I replace the HD in my 5k series without an original?
post #1 of 7
When I decommissioned my Replay some time ago I stripped the hard drive out of it and used it in something else... now I would like to get this unit working again. Is it possible to image a new drive with some backup from the net and get it working, without the original HD or a backup of it? Thanks in advance for any help! I sure have missed my Replay. TTYL
post #2 of 7
Or you could just buy a drive already imaged from someone like Mikeyboy(?).
post #3 of 7
Towards the bottom-right of the FAQ, you'll find a few links to Replay Images. Hopefully one of them still works
http://www.replayfaqs.com/
post #4 of 7
General Announcement
If one wants to paste a direct link to a page on l8er's board go to the desired page, right click, select properties, and copy the URL to clipboard (then paste it).
post #5 of 7
I LOVE L8ER'S WEBSITE! Here's the link!
Henry
post #6 of 7
I downloaded 5504_50103.zip and now worry that it might be a newer image file that will not skip commercials? I plan to run Wirns to preserve the CA function. Anyone know? TIA again for this info!
post #7 of 7
You didn't post your Replay model number. If you have at 50xx (or 5160), then any version will retain IVS and CA. If you have a 55xx model, then follow the instruction for which versions retain IVS and CA...
I could assume that since you say your are planning to run WiRNS, then you have a 55xx model and should follow the instructions to download an image that retains those features. 'Cause, if you have a 50xx model, then there is no need to run WiRNS to retain the features...
Henry
  Back to Forum: ReplayTV & Showstopper PVRs
