AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › PlayStation Area › Join the AVS Forum Folding@Home Team!
Join the AVS Forum Folding@Home Team! - Page 8
post #211 of 1815
BUMMER. I thought for sure when I woke up this morning and checked the team stats we would have broken the 1000 mark. BUT its 1012..SOOOOO CLOSE.
post #212 of 1815
yeah but we are closing hard on:
Official-ish PS3Fanboy Folding Team
Date of last work unit 2007-04-01 07:19:52
Active CPUs within 50 days 284
Team Id 57793
Grand Score 445497 (certificate)
Work Unit Count 1514 (certificate)
Team Ranking (incl. aggregate) 1009 of 57274
Next week they will be a memory. just like the ps3fan team.
avsforum rules! no question.
post #213 of 1815
Look again, its already 1008. Just 8 more to break into Top 1000.
post #214 of 1815
just checked 1003
post #215 of 1815
I found an option to download non-expiring work units. I think I will have to do that.
I saw on the FAH boards that there are no longer any non-expiring units. (I'm a new poster, so I can't link to the thread. It's in the Windows forum, and a thread called No Work Units?) So, using that setting will put you in an endless loop.
I've been trying to run one on my desktop, and the first attempt crashed. The next one seems to be progressing, but for some reason does not seem to be saving any of its progress - either in a logfile or scratch files. Hopefully this one completes - then I may try re-installing fresh. I started it yesterday morning and it's supposed to finish in 12 hours or so.
post #216 of 1815
AVS Forum
Date of last work unit 2007-04-01 11:22:29
Active CPUs within 50 days 200
Team Id 55280
Grand Score 455353 (certificate)
Work Unit Count 1625 (certificate)
Team Ranking (incl. aggregate) 998 of 57335
woo hoo!
We broke 1000.
post #217 of 1815
good job guys now if i could just get out of the 30's i put my pc to work also but it takes 4 days just for one wu (ps3 it is not) but every 1 helps top 100 here we come
post #218 of 1815
UGH. That's not good. It downloaded at 100000 unit and it's doing work on it now. I think it is a nonexpiring unit so that means it will freak out when it tries to send it back?.....in a month
post #219 of 1815
I joined the team. I have a few computers that I have folding and I just need to finish running the cat5 cable to my consoles (just moved into a new house on Monday) and I will have my PS3 folding. I might try and get the cables run tonight.. we will see
post #220 of 1815
I just joined. I kicked in my 20 WU's done so far. All I had to do was enter the team number under Identity and join team correct? It shows 55280 as my team.
post #221 of 1815
The ps3fanboy team is no longer a threat Good work everyone and welcome to all the new folders!
post #222 of 1815
I just joined. Go AVS team!
post #223 of 1815
Originally Posted by bgarner View Post
Well, decided to join and try it out.
I will assume that it will fold while my machine is on and nothing is happening?
You have to leave the folding program up on the PS3. If you don't open it, it won't auto-start.
I wonder how far team AVS will go? Top 500? Top 100? Maybe even top 50?
Roughly 9,300,000 points from 100. With almost 500,000 points so far in the first 10 days, we could be at that level in six months if our rate of folding doesn't slow down.
For those of you with multi-core, get the SMP beta client and run it. You score a whopping 1,700 points per work unit. Just make sure you have at least three days before the deadline otherwise you'll time out. (found that out the hard way) And if any of you have a quad core machine, you should easily be able to rack up roughly 2000 points per day.
post #224 of 1815
Originally Posted by LynxFX View Post
Awesome! Looks like our new teampage doesn't work yet.
http://fah-web.stanford.edu/teamstats/team55280.html
it now works.
post #225 of 1815
Hello everyone,
I just switched teams and Joined this one!
My folding Name is: Core_2
I have one PS3 folding 24/7 and three computers (one is a e6400 core 2 duo)
post #226 of 1815
If you press triangle over the Folding @ home icon you'll get options for auto-starting.
post #227 of 1815
Originally Posted by tindizzle View Post
Just added a dual Xeon 5355 (8 cores) system that I have until tuesday
. . . just couldn't stand being bumped down to that #3 slot, huh???
Go Team AVS!
--Dwayne
post #228 of 1815
Would I earn more points per day with the SMP client running- than two (non-graphical) clients running at once on a E6400 core 2 ?
post #229 of 1815
Just added 2 CPU's from my work to the cause watch out mcw00k down in 135th place is going to be coming for you all
post #230 of 1815
I see you down there mcw00k!
I'm in 76th place (only 7 WUs), but I'm going hunting for the #1 spot.
Ironically, the current leader is named PS3. Who are you, show yourself to us.
post #231 of 1815
We are ranked 900!
post #232 of 1815
Go Team AVS!
--Dwayne
lol how many computers do you have folding for you?
post #233 of 1815
tindizzle: how many CPU's do you have running? Also what do you have going?!?!?! Everyone, we need you to get your computers folding as well. We need to get AVS folding. What we really need is someone who works IT and has access to com rooms... we need some serious folding farms!!!
post #234 of 1815
Heh, PS3 is just those who joined the team but did not change the default name.
post #235 of 1815
I have one PS3 and one 2.4GHz P4 Core 2 Duo running the SMP client.
The "unfair advantage" I've had over the past few days is that both machines have spent 100% of their time folding, uninterrupted, for four straight days while I've been in the hospital.
And BTW, I'm just fine, at home resting comfortably. Anyone who wants to know more can find out in the Qualia 006 Owner's Thread in the Rear Projection forum.
Go Team AVS!
--Dwayne
post #236 of 1815
Glad to hear you are ok Zechman. Out of curiousity how did that phantom arm/shoulder pain happen?
To bad no picture of the look on the nurse's face when you said that... lol
post #237 of 1815
So far I have a PS3, an AMD X2 and a Quadcore running. Although on both the dual core and quadcore I'm only running the singlecore client. It is enough to keep me up in the ranks. Although I'm going to have a week off starting on the 13th, so I'll drop considerably.
Great work overall team!
post #238 of 1815
I have an old 3ghz PC, an AMD 3200 laptop, and my work machine going. Unfortunately, I'm falling behind today because my PS3 wifi drops constantly. I can tell from the stats that it's idling right now, disconnected, while I'm at work.
I'm surprised how well the folding program works in the background -- I can run it at 100% and it doesn't bother me at all. Even watched an episode of Top Gear on the laptop without a hitch, other than a bit of fan noise.
post #239 of 1815
Wait a second guys... how am *I* supposed to get to the #1 position if you guys keeping adding machines?
Good thing I have wifi... if not, I might have fallen behind since this condo I'm staying in here on spring break only has wireless....
....I'm going to have to start throwing every piece of idle hardware I can get my hands on to this project.... but it'll be another week before I get back home.
Jerz
post #240 of 1815
How long does it take for stats to show? I joined yesterday afternoon and have checked and I am not on the AVS stats list yet.
  Back to Forum: PlayStation Area
