I already had the Panny Format program, so I plugged my wife's camera
into the PC (saved her pics) and formatted the 1GB card in the cam.
I checked all the Panny format modes, and only the default (quick format) seemed
to work okay. The other format modes hung up.
I clicked on the firmware (zipped) file and told the unzipper to place the
files on my F: (removable drive is really a Nikcon camera) and it worked fine.
Turned on the TV, plugged the SD card into the maintenance slot and it
did it's thing. (On the TH-42PD60U, the slot in on the back of the panel).
Once done, it says 'Please turn off TV'. I think you should wait about
30 seconds and then press and hold the power button for 5-10 seconds
and it will go off. Just a quick 1 second press won't do it.
Before:
TV 0142-0110 (1.21)
After:
TV 0142-0510 (1.25)
Had to redo the time and date etc. But the darker areas of a picture seem
to have a bit more texture.
My wife kept saying that the news people were wearing too much makeup.
I think it wasn't the makeup, but clay face effects. Seems to gone now.
I'll keep watching for it. Got to tweak the PQ settings a little more now.
