Originally Posted by cappy1
Keep in mind that the nominal value of a speaker's impedance is not the lowest value that an amplifier may "see". Impedance is a frequency-dependent term, so you really need to look a plot of impedance vs. frequency to see how it behaves if you have a marginal situation in matching an amp to a speaker. For example a 4 ohm speaker may exhibit this nominal impedance at 40 Hz. If you go lower than 40 Hz, the impedance will drop below 3.5 ohms. In addition to the possibility of damaging the amplifier by creating large demands for current beyond its capability, the amplifier will start clipping once you exceed the capability of the power supply to provide the needed current.
Thanks. This is a a bit more complex than I expected when I started building this system. The reason I am getting rid of the Denon is that the friend of mine who got me into my main system of 5 VAs has a Denon and damaged his VAs.... (Baby Grands). This issue plus the disclaimers in the manual make it clear this is a no go. I called the seller at BestBuy/Magnolia and he agreed and apologised for his ignorance and will do a trade-in for the Yamaha which are explicitly OK at 4ohm. The reason I am doing this is that I get a major discount on the amp by buying the speakers at Magnolia... they cannot discount the VAs but they can discount the amp that goes with the speakers as a package.
I do not want to go into a better amp since this is really a secondary system for me attached to a smaller HDTV etc. My main system is based on Baby Grands.
In the manual of the Yamaha RX-V3800 it says 4 ohm is Ok from the main speakers but the other 3 must be 6 ohms or greater.....
I better start learning the technical nuances here.
