Originally Posted by gccdon
Hi,
Any thoughts on how ti assess this better would be appreciated.
Originally Posted by mikebyron
like the posted directly above me, I have a pair of VA's that I would like some tips on configuring. I can move them inch by inch and say I can hear a difference, but honestly suspect I can't. I'd like a primer or starting position or guideline for room placement. I have searched this thread, but admit to not reading all 67 pages.
Here were some tips posted by Dave Carr from awhile in this thread. They are some basic tips, but try them out cause they can help your placement out a lot.
"Four Rules:
1. Spread the speakers at least 9-10 feet apart, but up to 12-13 feet. Distance apart should form an equilateral triangle with the listening position.
2. Pull them out from the wall equally about 20-24", or more if space allows. This generally means just ahead of your AV rack. Alternately, you can place them about 2-4" out. The area in between these two points is unusable. The outer position will sound better so is recommended if you can. Using a music track with a centralized vocal and bassist, and move the left or right speakers to achieve a center image. If the vocal/bass are on the left, pull out the right speaker to adjust. If the image is on the right, push back the right speaker to adjust. These movements are typically small.
3. Toe the speakers in toward the listener, so that a line drawn out from each of the two speakers intersects about 1 to 1 1/2 ft behind the listening seat.
4. Level the speakers so that they are not wobbling, using the spikes to adjust. A bubble level can be used to make the speakers plumb.
Additionally, most Viennas will sound better if they are raked back slightly using the front spikes. This is usually not more than a full turn or two.
THIS NOT A MASTERS SETUP"
