Those are all very capable AVR's and I would also suggest you add the Arcam AV400 to your list.
But at the prices for the AVR's you indicate, the swing is from $1200 on the low end to $3000 on the high. Thats a pretty wide swing. What exactly is your budget? Finally it sounds like your concerned about power and rightfully so - running 4 Ohm VA's all the way around. What exactly are you trying to accomplish? The most bang for your buck? A little more info would be helpful.
