Need help:
I have HTPC hooked up via D15 connection (15 pins) with Epson 1080p projector, the cable is 10 meters (33 ft) long.
The image I have on the screen is flickering, not much, but quite annoying, and if I observe more there is a very light grey bar moving up costantly.
My dispaly of HTPC is set at 1280 x 720 resolution with 70 Hz.
Any suggestion how I can fix this?
THANKS
THANKS
