Hi,
My friend and I are building a couple of sonotube subs with RL-P15s in them. My friend wants to power his with the Buttkicker amp. He's found one for sale with an LFE (shaker) and he wants to use it and the subwoofer at the same time hooked up to the amp. Impedance is fine as both are 4 ohms so he'll wire them in parallel to get a 2 ohm load. My concern is that the levels of the two might not line up well as I'm not sure how sensitive the LFE will be. I'm concerned that the shaker could be really "loud" or really "quiet" compared with the sub. Obviously it has no real volume, but I'm sure you know what I mean.
Has anyone hooked them up like this? My friend's on a tight budget so it would be a waste to get the LFE and then have it no function optimally.
I am not trying to offend you and am sorry if I did. My situation worked temporarily, but eventually I wanted more shaking and different crossover point which requires another dedicated amp.
