Originally Posted by
tomanystraydogs
From the T42
73 manual:
Black Adjust:Off/Low/Medium/High
You can directly select the black level on the screen to adjust the screen depth.
Dynamic Contrast:Off/Low/Medium/High
You can adjust the screen contrast so that the optimal contrast is provided.
Gamma:-3 ~3
You can adjust the middle brightness of pictures.
Press the ◄ or ► button until you reach the optimal setting..
Color Space:Auto/Wide
Color space is a color matrix composed of red,green,and blue colors.Select your
favorite color space and experience the most natural color.
You can set the color reproduction space for the input signal to Auto or Wide .
White Balance:R-Offset/G-Offset/B-Offset/R-Gain/G-Gain/B-Gain/Reset
You can adjust the color temperature for more natural picture colors.
R-Offset/G-Offset/B-Offset/R-Gain/G-Gain/B-Gain:Changing the adjustment
value will refresh the adjusted screen.Select the desired option by pressing the
▲ or ▼ button,,then press the ENTER button.Press the ◄ or ► button until you
Reset:The previously adjusted white balance will be reset to the factory defaults.
My Color Control:Pink/Green/Blue/White/Reset
This setting can be adjusted to suit your personal preferences.
Pink/Green/Blue/White:Select the desired color by pressing the ▲ or ▼ button,,
then press the ENTER button.Press the ◄ or ► button until you reach the optimal
setting.➢
When using the My Color Control Feature,the current picture remains in
movement.Reset:
The previously adjusted colors will be reset to the factory defaults.
Edge Enhancement:Off/On
You can emphasize object boundaries.
I don't see any of the above settings in the previous models.
That's all for now.
