Update: It looks like one of my imagehost bite the bullet (imageviper). Will re-up as soon as I can.
***Please no hotlinking!!! ***
After reading through the previous HD vs SD comparison screenshots thread its time to go further with the topic. What is the difference between HD optical formats and HD broadcasts? Blu-ray and HD DVD?
We are already familiar with MPEG-2 broadcasts here in the US. In Europe however namely SKY, BBC and Premiere HD stations they use H.264 codec and has effectively trounced anything we see here. For more info go here.
Since its impossible for me to choose which movie frame to capture that will effectively show the best and the worst shot of a movie I will need feedback from members to help me find them. Macroblocking, grain, posterization, whatever.
The screenshots are best viewed using a high resolution monitor (DVI or HDMI) hooked up to your HD capable viewing set. These pictures are big files so dont "qoute" the pictures just indicate the reply #. All HD files are captured using MPC with external filters, captured as 1920x1080 BMP (except some H.264 files. They are saved as 1920x1088), using Photoshop saved as Bicubic quality PNG-24.
I highly recommend hooking up your monitor using digital connections. They show PQ closer to what you are seeing with your HD DVD/BD player.
All screenshots are made with the help of my Tandem 1.0 HTPC.
Disclaimer: Pictures are for information purposes only.
XylonHD, YouTube Channel, @XylonHD
Edited by Xylon - 6/20/12 at 5:28am
