It would be nice if they added even simplified instructions for this tool: http://www.mitsubishi-presentations....tor_tools.html
Trying to figure out if the HD1000 will work in my room (which it should), but I'm confused as to why the Mits tool shows two diff projector positions.
I'm looking at a 106" 16:9 screen (52"Hx93"W); my ceilings are 7'8" (and 6' 8" from where the screen will be mounted -- you can see via the link in my sig, it's kindof a tray ceiling).
The projectorcentral.com calculator doesn't take ceiling height into account, and gives me a throw of 15.4'.
Using a ceiling height of 92" and 2.5" for the RPA mount I'll be using, the Mitsu calculator gives me two locations, 12.7' and 15.4' Does that mean I could use either? Would the screen position change if I take the farther back position? You can't seem to "select" which mount position you'd like in the tool
