Hello everyone,
I just bought the Ipal portable AM/FM speaker from Tivoli. It allows you to connect any ipod or mp3 player via a headphone size jack input. I have the choice on using a dock connector cable that on the other end has the headphone size plug into the iPal or the simple headphone jack to headphone jack cable.
I know you are supposed to get better sound out of the dock connection from the ipod beacuse its not utilizing the iternal amp. Anyone have any experience with this and know if that causes more battery drain on the iPal?
By the way, it sounds great for such a little portable speaker system!
Brandon
Brandon
