While looking for the correct settings I experimented with some of the ones in the list. I found that the Motorola 12 seemed to have the closest match. Trying the power IR command worked. So did menu and guide. Well that is where things got strange. I could not get the remote to trigger the 6416. And when I went back and tried the IR command from the MX editor it would not work! Only after quitting the editor and restarting would it again activate the 6416.
Any ideas?
Oh by the way, I did go through the batch setup and had the 900 learn the buttons only to have that not work also! I am a bit frustrated with the editor and the lack of codes and programming tips. The manual is very hard to understand. All of the references to the 950 (I have a 900) confuses the actual method of setting it up.
Is there real motive here to force us to pay a tech? I did so when the initial install was done but I figured that the addition of a new DVR, especially a Motorola swap out, would be a snap. erg!
John
