Hi,
I just bought a used 36" sony xbr. Everything is in great conditon, except how to use it!!!!
The previous owner had lost the original remote, and bought a Sony RM-V310 remote commander (with programmed buttons). I have absolutely no idea how to use it. I fooled around with the menu & got 6 out of the 80 channels I'm supposed to get. Should I just buy a universal remote? Would that get rid of the pre-programmed info that I have no idea what to do with?
Also, when I bought it, we took a look at the picture and it was nice & clear. We hooked up a Sony DVD Dream System (and got it working finally), but the picture is a little fuzzy. We're just using the basic red/yellow/white cable hook-up. If we switched to an advanced method (S-Video), would that sharpen the picture?
What would I use for that?
Thanks!!
Mike.
Thanks!!
Mike.
