I hope this question isn't too far off topic for this thread but you fellows are very knowlegeable.
I drug my old (dead burner equipped) Phillips DVDR75 down from the attic to see if the component-in to S-video loop would correct the annoying aspect ratio issue. The unit fired right up and works OK after "resting" for over 5 yrs.
I hooked up a component cable set from my Comcast box to the "Ext 1" jacks on the DVDR75 and hooked up an S-video cable from the ext out jack to the L1 input on my Maggie 2160. The 2160 is hooked to my flat screen via HDMI. The DVDR75 setup menu displays fine but I can't get the cable feed to display. I made sure the DVDR75 input is set to Ext 1 and fiddled with everything I could find but no joy. Any ideas or am I trying something that's impossible?
It might be getting harder to get these things,i hope MP comes thru with at least one more batch. G.
MP must need to update their website.
Pulling the HDMI cable allowed the component signal through to be monitored my TV. I tried pulling the HDMI cable with the component cables hooked up to the DVDR75 but there's still no output through its s-video.
and the price went to high for a used unit,not much lower than a new one and there is no guarantee that the power supply,cords,and owners manual would be included.A power supply probably costs $20/$25 dollars and i could end up paying more for the used unit than a new one.
