Try look for info here
http://www.shinybow.eu/eshop/index.php?strana=search
The scart version is around $160 in Aus.
Damn Nikon! When using it's HDMI output the picture is full screen, hence the need for such a converter. I tried playing the SD card in my computer but had no luck
Using Widows Media Player or VLC I got sound but only paused video. Even if I was able to play the HD I'd have to get a BD burner and only play the DVDs in my BD player to retain HD, I think I'd be OK with SD if only better picture quality than I get from my Lenkeng.
which really gives the movie another dimension even though it's 2.35:1 the detail really pops on BD(it was only $6 at Sams
located on the left side of the individual post.
Reason for Deletion:Deletion Options
- Do Not Delete Message
- Delete Message
