Originally Posted by Tarheel72
it is physically impossibe to send Dolby TrueHD or DTS-HD MA out of the 1200 via any means what so ever. The only uncompressed audio is uncompressed lossless PCM. So the receiver is not decoding anything and is doing nothing more that a digital to analog conversion of that signal. If the disc does not have a lossless PCM track then the receiver is only getting a compressed PCM track, most likely 2.0, and converting it to a multichannel analog signal and then sending it to the speakers.
I don't disagree, I probably wasn't as clear as I should have been. My bad. You can send an uncompressed lossless PCM signal to the 3808 from the 1200 if the disc has it, digitally through an HDMI connection. The receiver then sends the unaltered signals to the speakers. As an alternative, you can send 5.1 analog signals through the coax 5.1 analog connections or 5.1 digital through the fiber optic or coax connections. Correct me if I'm wrong, but I don't think there is any real difference between an uncompressed lossless PCM signal and one of the newer codecs unless you have a disc that has a 7.1 track instead of 5.1.
BTW, what happened to the Heels in the tournament? I was so disappointed.
