Originally Posted by
Chris Gerhard
You understand that some displays have a mode that can properly format 4:3 DVD when the BD-P1200 scales?
First, I expect from the player to output 16:9 picture. It should take 4:3 and stick it into 16:9 frame, this is a basic and a simple task, and anyone who knows one thing about programming, can do it without getting a degree in higher math.
Second, the player not just badly formats the image, it stretches it horizontally, THEN cuts off portions from left and right. So, the picture does not have just bad aspect ratio, it is chopped.
Chris Gerhard
Of all the serious problems with this player, I find it odd that this issue which would be about number 100 on the list of problems for me is one that gets several complaints here. It isn't a bug, it is just the way the player is, you won't see the ability to pillarbox upscaled 4:3 DVD's listed as a feature.
It IS a bug. A simple, annoying bug, that says, no shouts loud and clear, that Samsung has crappy developers who either do not care or do not know what they are doing. And by the way, one of the reasons of getting the 1200 was the HQV chip, I wanted to get the best upscaling possible. In this context, your suggestion to switch to 480p sounds insulting. I hope OPPO licks the bugs out better than Samsung, so I could replace HQV with DVDO.
