A few weeks ago I received an email from the folks at Outlaw Audio announcing the availability of their new bookshelf. Since I was setting up a new theater, I thought it would be interesting to test a pair (or three) of these out. Since I am partial to wood veneer, I ordered three cherry speakers. They arrived a day later (one of the good things about living near the Outlaws) and were double boxed. They are packaged two to a box (not sure why, as they'd be easier to lug around if packaged singly), so one of the boxes had foam in place of the second speaker.
Workmanship is top-notch: the finish is furniture quality, and the cabinets are finished in what appears to be a matte lacquer. All sides save the front are veneered, while the front baffle is finished in black. The grilles are metal and fit into a groove on the front panel. So as not to scratch the cabinet, the edges of the grill that fit into the groove are covered in felt. This would also appear to stop any potential rattling that a metal grill might cause, while still making the grills easily removable.
Price for the pair is $1099 in cherry and $999 in black (which I haven't seen) or $1649 for three. I am a firm believer in having matching (identical) speakers up front and thus am using them as LCRs. This gives to me a perfect match and panning of action across the screen. Of course, placement will cause response differences (shelf vs freestanding) and Outlaw has tackled this problem with a rather innovative solution. There are two toggle switches on the back: one to adjust the tweeter level (flat, plus and minus 2db) and the other to adjust bass level to tailor the sound to corner, shelf or freestanding placement (flat, minus two and minus four db). This is the first time I've seen this much flexibility in a passive speaker (active speakers such as pro monitors offer these types of adjustments as a matter of course) but the last speaker I can recall that offered low end of this kind was the AR 10pi twenty-five years ago.
The speaker is a two way with 5" woofer and 1" fabric dome tweeter. The drivers appear to be high quality and used with and appropriate crossover (80 hz in my case) can play quite loud with 100 watts per channel. I had no trouble hitting reference level with for instance a Panasonic SA-XR57 and got additional ease using an Outlaw 990 and matching amp all in a 3000 cubic foot room.
Well, how do they sound? I'll post impressions in a bit.
