AVS › AVS Forum › Industry Area › HDMI Q&A - The One Connector World › hdmi, beginner . advice needed please.
post #1 of 4
ok guys, i hope im not opening a huge can of worms, but i think i might be.
(this is also my first post).
i read as much as i could about hdmi cables ect. to get a better knowledge about them. i still have a couple of questions...
first off. i have a brand new sony 46" xbr2 lcd.
i will be hooking up via. hdtv/digital cable.
soon will be adding a blu ray.(nothing for now)
my run will be about 12ft.
anyway. ive read a lot about the monster cables being a "scam". just buy a cheap one from monoprice ect.
whats the deal? with the length i described, do i need something like the silver serpent wire,? monster m1000 ect.?
this is my first big screen tv. i just want to do everything "right" and not cheap out on cables after spending a ton of $$ on a tv.
but if i dont need it , i wont spend all that money for nothing...
thanks for any help.
post #2 of 4
anyone?
post #3 of 4
I really like the 24 AWG HDMI cable from Monoprice.com at that length. Cheap, hefty cable. You can get a 15 footer for $26. It looks and performs as good or better than the Monster Cables selling for over $100!!
If you start going any longer than that I'd switch over to their 22 AWG cable. Mighty, mighty thick stuff!
The lower the gauge the thicker the cable.
post #4 of 4
Yes, the monoprice or bluejeans cable will work, and save you money.
