Originally Posted by
Ricsim78
This is for anyone with an LNT4066F that has a 1032, 1035, 1036, or 1037 firmware with the 1011 (Trident) board. This may also work well for LNT4065F or LNT4665F sets with the same board and firmware mentioned above. I also listed LNT4X61F settings, so you can try these with LNT4x61F TV's as well, just make sure you set the Service menu correct for them.
Go into your service menu (ONLY if you know what you are doing) and change the following values. Make sure you take screen shots of your stock settings so you can bring them back if you do not like these.
Shut your TV off. Hit Mute, 1, 8, 2, power to go into your service menu.
DO NOT hit enter or mess with the calibration menu! You can screw your picture up if you do this. If you accidentally do this, let me know and I can help you fix it. Use the down arrow and hit enter on Option Byte.
In the Option Byte menu, only change the following values:
Panel Option: Tulip-Side (Tulip for LNT4X61F series)
Panel: 40AMV (LNT4065 and LNT4066F), 46AMV (LNT4665F), 52AMV (LNT5265F), 40AM for LNT4X61F series (40AM, 46AM, 52AM per respective TV)
Gamma: 0.95
8-Bit color (try 10 bit first, if it looks like you went into rainbow land, put it back to 8-Bit!)
Mess with ONLY these settings, nothing else!
Hit return on your remote when finished, and go to the white balance menu.
In the service menu white balance, make the values look like this: We will be using the TV's picture menu to set colors. This evens all the colors out.
128
512
512
512
128
512
512
512
Exit the service menu (do not go to reset, just power the TV off) and turn it on. Set your picture menu like this:
Mode: Movie
Contrast: 90
Brightness: 50
Sharpness: 20
Color: 56
Tint: 50/50
Backlight: I like mine at 7-8, for a dark room try 5-6 (whatever your preference is. For a bright room in daytime I have mine at 8.)
Color Tone: Warm 1
Digital NR: Auto
Black Adjust: Off (Crushes Blacks)
Dyn. Contrast: Off (Kills Shadow detail, noticeable in photos viewed on the computer)
Gamma: -1
Color Space: Auto
White Balance:
R.Offset 21
G.Offset 18
B.Offset 21
R.Gain 7
G.Gain 17
B.Gain 26
My Color Control:
Pink 19
Green 15
Blue 15
White 15
Edge Enhancement: On
xvYCC: Off
HDMI Black Level: Low
Energy Saving: Off
After messing with my TV for 2 years, these settings make it look like I got a TV upgrade! Change the service menu to match mine first, then try these. I think you will find it looks amazing. The colors are perfect looking. Skin tones are natural, shadow detail is amazing. High definition content looks like you are really there, I cannot believe these settings look this good!
I use these with:
* WOW Cable's Scientific Atlanta Explorer 8300HD
* Sony PlayStation 3
* My computer's DVI to HDMI adapter.
All sources are using HDMI.
Note: Differences in the service menu are what makes one person's set different looking than another. If you set the panels the same, the display should also look the same (provided the same board, firmware, etc.). Even if not an exact match they should be close enough. The idea here it to set yours to look like mine, so you should see an almost exact replica of what I am seeing.
