i plugged in a computer through RGB component cables and once the pc was turned on it gave a fuzzy single colored look (usually pink, sometimes green instead). i cant reall explain much more. the screen sometimes goes off and this comes back on. I currently have a Philips 50PF9431D/37. Any ideas? Do i need to explain this problem more?
EDIT: OK, I used the SVGA to RGBHV cables. I was told it would work before, but as you can see I'm having trouble. Does this TV even support it?
