Hi Tony,
I'll put out a couple of other points to consider.
Although you may only listen to music 25% of the time, if you are like me, you are probably much more critical of the sound when listening to music than watching a movie/tv. Take away the screen as a distraction and most of us instantly become more critical of the sound. If that is true for you, it will put more importance on getting the sub/sat integration right if you are inclined to go with a Model LR3 for the front left/right. Don't get me wrong, the LR3 is a great product, but it does require a subwoofer to capture the lowest octave and about a half. Properly integrated it will sound fantastic. But if you end up going with a Model 6 or above, you can defeat the subwoofers for music listening or at least push the crossover point down to ~40Hz to help ease with the integration issue. It is usually easier to get really high quality music reporduction by using a speaker specifically designed for it in the front left/right positions.
The Model 6 was designed for placement close to a rear wall and will sound properly balanced in thsoe applications. The Model 7B was designed for in-room placement and tends to be at its best when it is at least a few feet away from the rear wall. Of course every room is different and these are just general guidelines.
The Model CC3B is a great center channel with exceptional range and dialog clarity. If you never heard the Model CC5, I think you would be forgiven for calling the Model CC3B one of the best center channels available today. However, the CC5 is that much better. We have had many customers upgrade from the CC3B to the CC5 and in every case, they have reported that it was a significant improvement to their system. It is not that the CC3B is lacking , just that the CC5 is that much better overall. So if you can fit the CC5, I would suggest you strongly consider it. If you can't fit it, then go for the CC3B and enjoy!
Hope this helps.
Andrew Clark
Aerial Acoustics
Hope this helps.
Andrew Clark
Aerial Acoustics
![ProcMediaServlet (params=[pa=0.5&sa=0&ry=400&rx=550&cr=0.0,0.0,1.0,1.0&ls=00006146464920130201203438090.JPG&nocredit=1&ci=47a3dc20b3127ccef2169450253400000040O08ActGzRs0Ytge3nwE&py=5.249507033924345&px=7.0&r=0&cb=16184818&p=1&ps=50&po=0&g=2.2&f=0&bw=0.2&b=1&ph=63198&si=00006146464920130201203438090.JPG&gc=1] actions=[CachedCanvas (RawOrProxyraw(com.shutterfly.imaging.rendering.imageref.ReferenceManager$Ref@1b4336a6, 600) | FitToSize(java.awt.Dimension[width=533,height=400], 2) | ScaleRGB(1.0365853309631348, 1.0365853309631348, 1.0365853309631348) | Sharpen(1.2999999523162842) | ShowPrint(java.awt.Dimension[width=550,height=400], 255, 1.0, 1.0, 1.0, 0, 0.800000011920929, 0.800000011920929, 0.800000011920929, 0) -> NativeCanvas(7F5CE02641C0))]) PixSense Recompression: PX_COMP_STD 172.16.17.12 2013/02/22 13:52:54.615](http://cdn.avsforum.com/4/44/50x50px-ZC-441ea306_ry3D400.jpeg)
Tell us what you think.
