Proceed HPA3 (500w @ 4ohm x 3)
Pulling sub duty is 1 JL Fathom f113, and will be looking to add a 2nd one when I get home.
But again, you're right about value/cost/sound.
Nice system, Carl.
Unless there is insufficient voltage swing in the single amp stage (which seems unlikely with >200w available), you'd probably be better off running just one of the channels in each of those three 1500A amps, and letting the other sit idle.>>Q. Will these amps handle a four ohm speaker while the two channels are bridged to MONO?
A. No. Remember amps bridged to mono will "see" half the impedance the speaker is actually presenting. Sustained 2 Ohm loads are not advisable with any Parasound amplifier.<<
