Question for LR5 Users:
I am using three LR5's across the front of my home theater "area" of a 6,000 ft^3 open basement floorplan. Due to the size and openness of my area I know that I need to use at least two subwoofers.
What subs have others been using that integrate well with the LR5's? I know the obvious answer might be Sw12's, but, I don't have the cash to purchase two. My second choice would be the Seaton Submersive, but, buying two would be above $5,000. I would consider buying only one, but, I am afraid I might have a difficult time balancing the bass response in my oddly shaped room. Even two used F113's would be over the $5,000 price point.
I am curious about the HSU ULS-15 in a dual drive system. They are fairly affordable at at around $1,000 per sub and seem to have positive feedback.
Just searching for opinions and experiences from other users to help me make my decision.I will also need to buy some type of EQ device. If it turns out that I need to go to the level of the Submersive then I will spread out the cost by buying one now and buying a second one when funds permit.
BTW, I want the subs to be tight, fast and controlled for music as well.
JD
