AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › What is best Avia test pattern for convergence?
post #1 of 4
I was working on testing convergence on the new RS1 - I ended up using the + sign test. I found out that the reds needed correction, but from what I can tell the test pattern now seems bang on - nothing but pure white crosses throughout the screen. Is this the best pattern to be using? Thanks.
post #2 of 4
I think that the consensus is that the best patterns to use are generated by 1:1 mapped signal generators or video processors - it leads to the least amount of display areas.
there are some test patterns you can download if you have a pc connected...
post #3 of 4
post #4 of 4
yeah I would try to get a 1080p feed into the RS1, the avia patterns are pretty coarse.
