AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Software › Is soundon b ray /hd dvd tamed down ?
post #1 of 2
I just read the reviews of House of was and Flight of the Phoenix at hddvddigest.com and both audio reviews makes me think something is wrong.
On my system I recall HOUSE OF WAX had some nice dynamics and bass in the end in particular while F OF THE PHOENIX is a monster of bass.
i use speakers equipped with 15 and 18" gunners and there's about 3000watts behind (sensitivity is 98-99dB)
so what is your feeling ? if there's a difference in levels (while compression is reduced on bray and hd dvd) ? and if yes, the players ?
or is it like widescreenreview which is quite harsh on HD reviews, probably so they keep more pts in reserve as the mastering improves....
post #2 of 2
David600,
Br and HD lossless sounds like PCM off laserdisc. I know you remember those.
  Back to Forum: Blu-ray Software
