got a jl audio sub and optimal sealed size box of 1.25 cubed, optimal ported size is 1.75
i chose sealed due to trunk size restrictions
sounds pretty good with rap but minimal with rock music and i seem to listen to more rock than rap which i knew beforehand but i think i would prefer it to be passive radiator or ported yet have the small box, especially since i already bought it and seeing i'm not pushing much wattage i wonder if i'd be better off altering it.
so 2 questions:
i have 2 old 6-1/2" klipsch subs i'm not using. what would happen if i stuffed the box with polyfill and cut 2 holes for those 6 inchers to use for passive radiator design?
or
what would happen if i just cut for a tuned port and used lots of polyfill?
and can i use corrigated flex pvc pipe (easy to cut and bend to achieve long size if needed plus i have some) or must it be smooth walled, i dont know how corregated ridges would effect airflow, maybe someone can simulate it for me?
would either one make it worse like more distortion or what?
so 2 questions:
or
