Okay... so I had to do it! I purchased the HV20 yesterday at Best Buy and just had to go and purchase the HD7 today to do my own comparison. I can't just sit around all day and wait for you guys to do it!!
So my first test was tonight in my living room. 1 overhead ceiling light which consists of 2 75 watt bulbs. 2 floor shaded floor lamps. Both cameras tri-pod mounted. I wanted to start with a low-light test before I do my daytime tests tomorrow. I figure this is the most critical test for alot of you guys. I by no means am a professional tester or have any testing equipment to measure s/n ratio. The only test equipment I have are my eyes and my 1080p set.
Quick initial impression is that the Canon HV20 outperforms the HD7 in low light situations. I had thought because of the 3CCD array that it would actually perform better but that is most definitely not the case. My wife and I came to the unanimous conclusion that the Canon just has better image quality based on recorded video. The JVC's shadow delineation is not smooth at all and actually showed a huge hotspot on my wife's forehead cast from the overhead light that the Canon rendered much more smoothly with no hotspot. Also where the light was hitting her hair the Canon revealed detail that again was blown out on the HD7. I tried exposure compensation but that did not help. I can only think something in the recording algorithm is doing this possibly?? I don't know. Another area where the Canon was better was in CA/fringing. The HD7 revealed blue/purple CA around my wife's black jacket against our light sage green couch and red fringing around a white piece of paper that was on our coffee table. Again, the Canon handled this flawlessly. Noise levels to me looked almost the same with a slight nod to the Canon and actually a clearer picture too.
Build quality of the JVC is nicer however. It's a little bulkier in the hands which for me is not good since I have relatively small hands. The Canon for me works better here. The lens protector on the HD7 is manual and is open/closed by a switch on the front right side. The manual focus ring is a nice touch. Pulling up videos is faster on the JVC due to the hard drive. No big surprise there. BTW, the HD7 can be had at Circuit City for $1499 if interested. They have the in stock in store, though website says they don't. But, they do. Same for Best Buy. Best Buy prices matched CC for me. None the less, I will almost def. be keeping the Canon. I'm going to shoot some outdoor tomorrow to see if things improve but the clipping/hot spots/loss of detail & fringing have me concerned.
Sorry for such a short impression but I know you guys are eager to have a comparison between the two.
Oh and the HD7 does NOT have 24p. It has cinema effect like the Sony's which simulates 24p but is nowhere near as good as the Canon's true 24p.
