I thought I would start a model-specific thread for this unit and its siblings. If I have missed a preexisting one I apologize and please let me know.
I picked up the new Magnavox ZV450MW8, DVDR / VCR w/ ATSC and digital cable tuner.
After making far too many rounds, I was surprised to now suddenly have 5 DVDR w/ ATSC choices at WalMart, with empty shelf spaces for two more coming soon.
No HDMI
the VCR does not output to S Video or component.
In the manual's words it "records 16:9 as 4:3". I have only tested for one night, but it clearly correctly records the entire signal to the entire 720x480 frame. It does not waste resolution by recording any bars into the picture. So, if you have a 16:9 TV and set the 450 as such, the recording will fit correctly.
The unit is a little loud and vibrates noticably, much more so than the LG 797 I tried first and just returned. This makes me nervous about longevity.
It tunes digital TV slooooowly, so anyone needing it as their STB can forget it. I could live with it solely for recording.
It always records +/-RW in +VR mode. My analog Samsung gave the choice of video mode. I only have -RW on hand as that was all the Samsung took.
I dubbed a tape to disc. Then I added chapters on the unit, something I had always saved for the PC. I figured since it was going to use VR mode anyway, I might as well give it a try. The chapters appeared correctly.
Finalizing took forever. I wonder if it would have gone more quickly without the chapters. When imported to the PC I noticed all the chapter break points had the highest cell IDs scattered throughout the otherwise sequentially numbered cells of the title. I figure it spent a ton of time chewing and re-writing to split, create, and re-position the new cells. This is something I can do in a heartbeat on the PC.
Dub quality seems ok. It was a pretty poor tape I used last night. I may redo one of the two much nicer tapes I did on the LG to get a more fair apples to apples comparison.
Mike
No HDMI
Mike
