AVS › AVS Forum › Audio › Surround Music Formats › Doors Box-DTS?
Doors Box-DTS?
post #1 of 8
I just picked up the Doors Perception box set that supposedly has all the albums in DTS on the DVD's. Has anyone else noticed that the DTS audio tracks don't seem to be there? Any other DTS CDS/DVD I play through my Oppo and my Onkyo gets recognized as DTS and uses the DTS surround mode. These don't seem to really be DTS at all. Has anyone else had this problem? Getting all the album in DTS 5.1 was my main reason for buying this...Any ideas?
post #2 of 8
Are you playing the DVD-Audio section? That's the high-quality version, and won't come over an optical/coax link; you need to use HDMI, i.Link, Denon Link or 6-way analogue cables.
The DVD-Audio disc should be authored to allow you to access the low-quality DTS version from its menus, but if it doesn't, find your player's set-up menu and tell it to play DVD-Audio discs as DVD-Video.
But that's only a stop-gap measure really. You should get your cabling sorted out so you can hear the full-quality advanced resolution DVD-Audio.
post #3 of 8
When I put the DVD in it only shows 2 audio options, Advanced Resolution Surround and Advanced Stereo. No DTS. I have my Oppo 981 hooked up using a coax and the 6 different audio cables to my Onkyo 804. Like I said I have many other DTS DVD's and they are cognized with no problem. Are you saying that the Advanced Resolution Surround is BETTER than DTS? I have been listening to the Advanced Resolution Surround and my Onkyo just plays it using NEO 6 surround mode, not DTS. I will look into my Oppo's setup menu, but this is still confusing... Thanks for all the info...
post #4 of 8
This is a DVD-Audio disc. Your other discs are presumably DVD-Video discs, or DVD-Audios that allow you to access DTS from the DVD-Audio menu.
DVD-Audio discs have two separate menu systems - one which DVD-Video players see, and one which DVD-Audio-capable players (like yours) see. The menu for DVD-A players is supposed to include everything from the DVD-V side, but this disc apparently fails to offer the DTS version in its DVD-A menu. As a workaround, your player should have a set-up option which allows you to see the DVD-V menu instead. But you don't want to use this, because...
The advanced resolution sound is better than DTS. It's high-resolution, uncompressed audio. Bit like the difference between CD and MP3 (except advanced resolution is better than CD, and DTS is better than MP3, but the same principle).
You shouldn't be using any surround modes on the receiver - make sure you're selecting the multi-channel input. That's the MULTI CH button on the remote.
When using the multi-channel input, the receiver won't do any bass management etc, it's up to the player, so you'll need to make sure speaker sizes and distances are set on the player.
post #5 of 8
Yes it is.
Your receiver is processing the stereo feed, not the multichannel layer. Check your setup in the Oppo to be sure you've chosen multichannel as default.
Good luck,
Lee
post #6 of 8
With the doors box set you would need to access the dvd-video portion to get some of the extras, along with the videos included. In your Oppo set-up there should be an option to play the dvd-video when a dvd-audio disc is inserted. As others have said, this usually isn't a problem because you can access both from the dvd-audio menu. But The Doors and other discs have been poorly authored and require you to go into your settings on your player to play the dvd-video part of the disc.
post #7 of 8
Thanks guys. The "problem" was with my mis-understanding of the Multi-channel setting on my Onkyo. Once using the multi-channel function things are how they should be. I must say that I'm now REALLY enjoying this box set. They seem to have done a very good job in creating the 5.1 mix. The extra tracks and bonus video tracks are great too and these are just the dvd's so far. I haven't even listened to the stereo cd's yet. Thanks again.
post #8 of 8
That Multi-Channel mode on the Onkyo eluded me for a while as well.
  Back to Forum: Surround Music Formats
