AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › JVC RS1/HD1 CC filter tweak
JVC RS1/HD1 CC filter tweak - Page 4
post #91 of 132
I have finally done a bit testing with the 81C filter...
Here's before and after adding the filter:
post #92 of 132
Below are CIE u'v' charts, rather low rez images, showing the before and after results of reducing the color control to it lowest point. Looking at these alone would give the impression that the primary locations have overall improved.
Does this mean that adjusting color to -20, versus at 0, actually makes the colors look more like they should?
post #93 of 132
Maybe it is my ignorance talking here, but in the 'before' sample...couldnt you just lower blue a little bit to get it tracking just fine?
post #94 of 132
The goal here is to optimize contrast
post #95 of 132
Without compromising color!
RGB histograms don't cut it as they are only part of the story - you need to run your xyY measures for your RGBCMY gamut and plug them into the CIELCH spreadsheet linked in this thread and report back.
post #96 of 132
Am I the only one who thinks that this is a terrible idea?
At best using a filter will get you somewhat higher on/off CR. This projector already has extremely high on/off CR. I'm skeptical that any additional improvement in this regard would be meaningful. Furthermore, using a filter will usually substantially cut your available light output, will require recalibration of the gray scale, and may cause other optical problems, depending on the quality of the filter.
I just don't see it.
post #97 of 132
But what happens if you need to cut light output in the first place? Then this would be one of the best way as the HD1 does not have a manual iris control. Cutting light output with the additional advantage of increasing contrast. Double win isnt it?
Oliver
post #98 of 132
Tom - I'm with you that this is *probably* not worth the trouble and possible side effects. However there is a key benefit you may be overlooking and its not increased CR...
This approach (if it works with minimal side effects) could potentially provide a much improved absolute black level. So while I wouldn't care much about going from 15,000:1 to 20,000:1, it would be fantastic to see absolute black level drop significantly. That being said, someone reported that lumen loss was still in the neighborhood of 25% with this filter. Once I heard that I lost most interest in trying this. Still potentially a good outcome for others.
post #99 of 132
I agree 100%. I will do some more measurements when I have time...
post #100 of 132
But in my opinion still not high enough.
post #101 of 132
This surprises me a little, not that you feel that this is not a good idea but because you, more than most, understand the concept of compromise to achieve the greater good. All else being equal, sure, sacrificing color makes little sense. Sacrificing color to obtain appropriate lumens on the screen to within standards which can help reduce the visibility of noise many see with this PJ to increase depth and 3D effect and things aren't quite so cut and dry, add in a couple thousand free points to the CR and things become even more less cut and dry should there be color or other compromise. Conversely would you calibrate a customers display to achieve that last few % for perfect color if that meant possible eye-burning lumens and a 25% cut in CR? Some would find that acceptable and some not so much. At this point I don't see where "recalibration of the gray scale" is an issue as it appears anyone experimenting has equipment.
Assuming my equipment and methods reasonably reflect reality I believe I have shown that at least with the filter I experimented with there was no sacrifice in color to obtain increased CR and a decrease in lumens to better levels in my setup. There was one negative which may be associated fully to the cheap filter I used caused increased obvious optical distortion with increased use. Again, assuming my measurements reflects reality, using this filter appears to little different than using a ND filter to cut brightness and seldom have I've read of any negative side-effects using a good quality filter for this purpose. I can only surmise that using a decent quality CC filter will reduce the negative result of using a filter. I've also learned that there indeed can be optical artifacts which at this point I can only attribute the specific (not glass) filter I used. Each end user has his/her own set of "meaningful" priorities for which they feel will offer to most life-like image factored on many variables, one being color accuracy.
Quite honestly I normally balk at putting anything additional in front of the lens except the screen and began this experiment primarily to provide myself with another project to keep myself occupied with the possible off-shoot that something could be learned (+ or -) from it. What I've learned so far is that, if you're a little lucky, using a CC filter tool to calibrate RGB balance and bring down lumens might yield surprisingly good results by maintaining CR close to torch mode levels and increase absolute black levels while doing so, and I neglected to mention that with this PJ, the reduction in absolute black level also decreases the visibility of bright corners should that be an issue with present setup. How much a PJ owner is willing to compromise to trans-morph to a seemingly better set of problems is anyone guess.
I look forward to trying the Hoya 85a filter I have coming in but it's on back-order till May 11. I also look forward to anbjornks color fidelity measurements.
post #102 of 132
Worth the Trouble?? Most here spend tens if not hundreds of hours tapping on keyboards often about nothing at all, what's an hour setting up a filter.
The 25% lumen drop is with using an 85A filter which is very aggressive, the 85C is a much paler orange which should have far less lumen drop.
post #103 of 132
I look forward then to hearing about the results using the 85C. I'd be all for it assuming overall lumens falls less than 10-15% and ANSI CR and color is not significantly impacted. I've heard others say in particular that introduce any filter can really impact ANSI CR.
post #104 of 132
I've been reading the same thing about a reduction with ANSI CR which makes perfect sense and I've been meaning to measure it but feel I don't have the gear to do it properly (seems like spot meter would be ideal for this measurement). However I just put on a 16 square ANSI test pattern and measured with the meter facing the PJ lens about 1/4 distance from screen to projector with sensor centered in one of the squares. Typcial ansi tests require several measurements from different screen locations but this will have to suffice for now. I used the PJ's vertical flip option to switch the square from black or white.
ANSI CR no filter = 299
ANSI with filter= 276
An approx 8% reduction in ANSI CR with filter installed.
Just for conversion sake my first ANSI measurement with filter installed spit out a CR of 232 but I've doing a little work in the HT which I anticipated would create a little dust so put on the lens cap on the PJ but left the filter uncovered. After noting the lowish ANSI I checked the filter and there was a slight coating of dust on it which I cleaned off most with some air after which I attained the 271 measurement. Keep your room and optics as dust free as possible, even a small amount of dust is an ANSI killer!
post #105 of 132
ANSI CR no filter = 294
ANSI with filter= 271
Very encouraging. Ideally the ANSI CR measurements would be taken very close to the lens 6-18" with treatment on the ceiling above the meter assuming the pj is ceiling mounted and within a foot or so of the ceiling. But even with your rough measurement it sounds pretty good. This is with the more aggressive filter right? What about the more pale filter you mentioned - is that on tap for testing?
post #106 of 132
I ran the test again after giving both the lens and filter a blast of air which increased the numbers slightly which I've edited my previous post with. I'm a little surprised, I thought the ANSI with filter would be less than that. Yes these measurements are with the Cokin 85A filter which I believe is the most aggressive orange filter of this series, I have a large Hoya 85C on order which I anticipate will have less than half the lumens cut than the 85A but with a slightly different green blue filtering ratio which may or may not work as well for my situation which could alone impact CR measurements. I should have the Hoya middle of May and will post some measurements when I do.
post #107 of 132
It's not the concept I have a hard time with. It's the implementation. For this particular PJ, I just doubt that a small increase in CR would be visible, whereas the drop in light output and potential optical distortions would be. I just don't see how a greater good is achieved. It sounds more to me like an obsession with tweaking for tweaking's sake.
post #108 of 132
What's wrong with that?
post #109 of 132
You are correct the reduction in light output with this particular filter in place is quite noticeable but there are many instances where this can be beneficial. You are implying that maximizing or maintaining lumen output is the only option for all installations, any methods employed to reduce lumen output therefore is undesirable. Using filters to cut lumen output is fairly standard and accepted practice, the benefits can outweight the negatives.
I'll state again that I've found a few positives using the filter:
1- Increase CR of 20 %. whether it's visible is debatable but I'd could never imagine an instance where an owner or calibrator would throw away CR by 20% if it could be avoided and just say you can't see it anyway.
2- Drop in lumens, same effect as employing an ND filter. Some situations could welcome this.
3-Decrease visibility of bright corners.
This thread was started to provide a few measurements in an attempt to quantify the results of using the filters as opposed to relying on intuition of their effects. In the process I have noted some subjective positives and a couple negatives in my setup which may or may not be Cokin filter specific. If you wish to dismiss what I, at this point, subjectively feel may be an improvement that's fine, hopefully whatever measurements are taken by myself and others which may be helpful to those interested. I note from your site that you are ISF certified, have you first-hand witnessed and/or measured the negative effects of using filters?
Tweaking for tweaking's sake....never!
post #110 of 132
Thanks - these measurements seem right on target. For instance Greg measured about 300 ANSI CR and I did as well. Having you measure about the same then gives us confidence in the measurement with the filter. 8% loss is not a show stopper for me so that is encouraging indeed.
A few questions:
1) Sounds like the filters take a while to get / ship - middle of May? How much do these run?
2) I'd love to see a CIE chart without the filter vs. with if you have an opportunity to snap one off at some point.
3) Is there ANY impact on the razor-sharp focus or clarity of the image when the filter is used? Even the slightest noticeable amount would be a show stopper for my tastes.
4) How do you have the filter attached to the RS1? My understanding is that because of the notch on the RS1 a filter does easily slip/fit over the lens?
5) I recall reading that these filters can change the color output over a relatively short amount of time due to usage/heat or whatever - causing the color to drift. Any truth to this?
Thanks for keeping us posted. I'll be real curious about how things work out with the 85C compared to the current one you are using.
post #111 of 132
Tom as I mentioned earlier I agree that there is likely little or no perceivable benefit from the increased on/off CR. However there is likely a huge benefit on fade to black scenes due to a significant lowering of absolute black level, without (hopefully) too much lowering of the white level (to me I'd accept up to about 10-15% loss as a tradeoff).
post #112 of 132
Since I don't have an RS-1 yet, I can't speak to the other questions, but from using a number of filters with other projectors, I've never had any reduction in sharpness using a good quality filter. A glass filter like the ones talked about here will not change over time. Some of the resin and gel-filled fillers are susceptible to change however, which is why their use with projectors is not recommended.
As an aside, I've never used an 85 series filter, as I've had good results with the 81 series, but it looks like the RS1 may match up better with an 85. I'll eventually check a few out and see what does the best job.
Thanks for all the info guys.
post #113 of 132
.......A few questions:
1) I'm in Canada and the Canadian online dealers supplier was out of the large 77mm filters. I suspect USA purchases would be quickly supplied. As usual I paid too much, good filter price of about $51 CAD plus crazy shipping and crazier tax. A fact of life living in Canada.
2) I posted a couple CIE charts on the first page of this thread of what you're looking for. Are those what you're looking for?
3) Anything which reduces clarity or sense of focus drives me nuts so I was expecting this to be a problem. Looking at the on screen menus I see no changes whatsoever, the text is still razor sharp. Watching movies I at times feel there may be loss of optical resolution, other times I'm convinced there is not. Without matching brightness levels and eliminating personal bias it may be difficult to ascertain for sure but I'm leaning towards the "no loss" camp. (this is when the filter is not suffering the effects of heat)
4) In post #14 I have a photo of the temporary filter and holder, this hangs in front of the lens via a piece of tape. The filter holders circumferance is the same size as the PJ lens. The new Hoya filteron order is 77MM and I measured the PJ shroud at about 78MM, my plan is to use a very small dab of tac "n" stick on the filter threads and push in in place.
5) I haven't noticed any drift from the Cokin filter but there does seem to be a amount of color variation across the screen and in the corners. This could be fault of the filter but more likely non-uniformity of the panels.
post #114 of 132
lovingdvd
He is not posting CIE xy charts anymore because of coming to the understanding how they have nothing to do with visual perception. Those that calibrate only to the CIE chart are making the picture visually worse - it does not consider color brightness for decoder levels - or the perceptual differences in saturation influenced by brightness. He is posting LCH data instead - which covers all three perceptual dimensions - lightness, chroma and hue.
So far a reduced color control combined with the filter - slightly improving light colors (CGY) and worsening dark colors (BMR) for overall little chroma difference at a cost of color lightness reduced off the standard. The filter itself causes color errors to shift around - but arguable if that is percievable or not. Hugh2 owes a run with different levels of color control to see if a compromise setting can be found.
post #115 of 132
Originally Posted by krasmuzik View Post
lovingdvd
I apologize to MikeSRC, I sorta forgot about posting that, I ran the test last week but there's nothing of value to report, no compromise could be found. The color control does not function in a linear manner or equally for saturation and brightness. The primary color locations move relatively little for the first -14 or so clicks then really begin moving between that and -30. On the other hand color brightness is so sucked out by -15 where the primary movement gets ramped up that any sort of middle ground is impossible.
If there were more primary movement between -4 and -8 then perhaps a good compromise could have been reached but such was not the case.
post #116 of 132
....So far a reduced color control combined with the filter - slightly improving light colors (CGY) and worsening dark colors (BMR) for overall little chroma difference at a cost of color lightness reduced off the standard. The filter itself causes color errors to shift around - but arguable if that is percievable or not....
Just wish to clarify that when I introduced the filter and took measurements the color control was not manipulated in any way from the pre-filter measures. The only adjustments were to the RGB controls to get gray back to D65 or thereabouts. Any changes in color lightness is do to either the filter, RBG controls, equipment tolerances or UBD error, but definitely not the color control.
Here are my most recent numbers again, posted in the previous page.
Filtered first:
___dE(u'v')__dL____dC____dH
R__15.6____1.5___15.3___2.7
G__28.0____-1.3___28.0___0.0
B__4.2_____-1.7___2.3___-3.0
Y__20.4____0.0____20.4___0.7
C__15.6____-1.0___15.5___0.6
M__6.3_____0.5_____5.8__-2.4
No Filter
R__19.3____2.5____18.9____2.7
G__30.6____-1.3____30.5____2.5
B__4.3_____-3.3____-2.3____-1.6
Y__20.7____0.3____20.7____-0.2
C__16.5____-1.7___16.4_____0.6
M__8.9______1.0____8.1_____3.7
post #117 of 132
Hugh2
I am lazy - can you do a delta dE/dC/dL/dH to show the difference the filter created (subtract the pre/post data)
post #118 of 132
No problem. Positive numbers denote impromement with filter, negative numbers a worsening with filter.
___ddE(u'v')_ddL__ddC___ddH
R__3.7______1.0__3.6_____0
G__2.6______0____2.5____2.5
B__0.1______1.6___0____-1.4
Y__0.3______0.3___0.3___-0.5
C__0.9______0.7___0.9____0
M__2.6______0.5___2.3___1.3
post #119 of 132
I've been reluctant to make any claims or proclamations with respect to my measurement result without corroborating measures so in an effort to appease my own doubts of accuracy and relevance or, at the very least, consistency of my measures I ran a complete new set of and ran them through Krasmuziks spreadsheet. Keep in mind that it's been two full weeks since I ran the measures posted just above, my tripod/sensor is in a slightly different location.
I ran 100% windows and calibrated the 100% white window pre-filter to dE .26 to D65, and managed to get 100% white with filter to dE .14 to D65. I have not touched the color control and didn't even check to see if all was still ok.
Filtered first
__dE (u'v')_dL____dC_____dH
R___17.6___2.1___17.3___2.7
G___28.5___-1.1___28.4___0.4
B___5.8___-1.0____4.6____-3.4
Y___20.8___0.2____20.2___-4.8
C___16.4 ___0.8___16.0___3.1
M___7.7____1.4___7.5____-0.9
No filter
R__20.7___2.9___20.4____2.7
G__31.1___-1.2___30.9___2.9
B___3.7___-3.0___ -0.7___-2.1
Y___20.5___0.4___ 20.5___-1.4
C___17.3___-1.6___17.1___1.8
M___10.6 ___.6___ 8.6_____6.0
And the "delta dE/dC/dL/dH to show the difference the filter created"
R__3.1______.8___3.1_____0
G__2.6______0.1__2.5____2.5
B__-2.1_____2.0__-3.9____-1.3
Y__-.3______0.2___0.3___-3.4
C__.9______0.8___1.1____1.3
M__2.9____-0.8___1.1____5.1
With the exception the barely perceptible changes (about 3 dE) of yellow/magenta the relative dE changes from the filter are very consistent compared to my previous results Essentially, the end result of using the Cokin 85A filter with my RS1 has measureably improved on average color chroma, lightness and hue. Any measured change ultimately is under delta of 3 which for most intent and purposes is imperceptable to the "Hughman" experience even in side by side comparison.
I think I found my new moniker.
post #120 of 132
At some point during this thread I stated I'd attempt to find a compromise using the color control which yields the least average delta error between color brightness, color saturation and color hue. I did some quick testing last week focussing primarily on the chroma movement of gree and reported no comprmise could be found but this was kind of a knee jerk reaction to just viewing the numbers in Krasmuziks spreadsheet accompanied with viewing the shifts within the CIE charts but I did not actually average all the results.
I felt I short changed a few including myself so I again ran the numbers tonight but calculated the averge delta error to determine what I originally indicated I would. I measured the xyY values while reducing the color control from -2, -4, -6, -8, -10, -15, and calculated the average error of lightness, chroma and hue for each position to determine which offered the best compromise. I re-established 100% white level before each run as lumens increased slightly throughout the test. To calculate average I performed root mean square (RMS) calcs from the dEu'v' which has accounted for the weighting assigned to LCH as they combined relate to perception.
Here are the RMS results, the first at -2 which is the proper color calibation using DVE filter and Getgray disk. on my setup which does give the best overall lightness error.
-2, RMS dE= 17.9
-4, RMS dE= 16.4
-6, RMS dE= 15.4
-8, RMS dE= 14.8
-10 RMS dE= 15.4
-15 RMS dE=16.0
I'll also submit a straight average of dEu'v' for each color position:
-2 average dE=16.1
-4 average dE=14.2
-6 average dE=12.4
-8 average dE=12.9
-10 average dE=11.2
-15 average dE=15.3
Utilizing the LCH model which takes into account color brightness and it's perceptual effect on saturation it's stands to reason that the goal would be to minimize the average delta error for primary and secondary colors lightness, chroma and hue. With that goal in mind setting the color control between -8 and -10 appears to the sweet spot in my setup and accounts for the lowest RMS and average delta error taking all the above factors into account.
I'm quite surprised at these results, assuming the measurements and calculations are accurate then using the LCH model to calibrate overall color accuracy shows the best perceived result could be anywhere between -4 and -15 on the color control. The presumably filter calibrated result of color control at -2 would appear to very setting not to use if the intent is to maximize overall color accuracy.
