I'm finishing off my basement and setting up a theater room. I now have a dilema. This is my first post, so I won't put pricing in since I'm not sure it's allowed. I will give general ranges though.
The length of my room will be approx 18.5ft and the width is at 14ft (9ft ceilings). My best guestimate is that the viewing distance will be between 12 and 14ft centered to the room. A side couch will be closer, but I'm planning based on the primary seating position.
Here's my dilema. I have the opportunity to get a great price on last year's Panny 58PX60--let's say less than $2,400. However, I can also get a pretty good deal on the TH50PZ700U--let's say a shade over $2,500. Safe to say, I like the look of the new models better. While that is important to me, it is certainly less important than image quality. Even with good pricing, the TH58PZ700U is out of my range, so I can scrap that idea. I could get a TH50PX75U for a shade under $2,000.
Given the above, my concerns/questions are:
Based on my expected viewing distance, would I be better off with the larger 58" or the 50" that has 1080p. I know a lot of folks don't buy into the 1080p hype, and I've got my questions about it as well (assuming most normal viewing situations and smaller screen size). However, this would be a 58 and it sounds like when you get 50 and over this issue can come into play more. So, at 12 to 14 feet, any opinions on whether the 50" at 1080p would be better than the 58" at the lower resolution. I do know the contrast ratio of the new 1080p panny is lower than the 58" model I've quoted. I've read some post that argue that's more important than resolution anyway (all else being equal). I've got a 42" Toshiba - last years model - upstairs. When I sit within 6 ft. the pic gets grainy (current digital cable source - dvd is pretty good). Primary source will be HD cable, and DVD player. Though, if I got the 50 1080p, I was planning on buying the new OPPO upconvert DVD player--HD and BlueRay are still a bit out of my range. Speakers on the unit don't concern me--so if there's any difference in speaker performance on the display itself, that won't affect my decision.
I realize a lot of this boils down to personal choice. This will be used primarily for movie viewing - no gaming or pc use planned. Like everyone, I'd like the best image for my money. I don't want to oversize the display for the room though. 58 would be great, but not if it doesn't fit the room or if based on the viewing distance the 1080p would be better.
Thanks for any input any of you provide. I'm all ears. Love this forum. Been a long time reader and first time poster.
