wasnt sure what was the correct section for this post, but this one seemed to be the closest:
i was wondering what were my best options for an outdoor television. i am currently building a house in New Orleans. I will have a large covered but open air, back patio, with fans, outdoor furniture, etc. Ideally, i would like a an adjustable arm, wall mounted plasma, which would be no problem for me to have wired and setup, i am sure.
but my question lies in how any particular tv will do in this environment? it will be out of the range of direct sunlight and rain, but obviously down here, humidity and heat are very high, etc...
is this even doable? should i be thinking about having something setup so i can easily hook up a plasma or lcd, then unhook it and store it inside?
any advice or reports of similar endeavors would be greatly appreciated
Paul
Paul
They might be cheap but they do not offer enough protection for an outdoor screen.
