AVS › AVS Forum › Video Components › DVD Players (Standard Def) › OPPO Digital DV-970HD: up-conversion patch
OPPO Digital DV-970HD: up-conversion patch - Page 13
post #361 of 364
Originally Posted by vudude101 View Post
They told me it's the cable but the cable works with my PS3 fine.
It is not unusual for a cable to work fine with one piece of equipment, but not another.
For troubleshooting, use a short cable, connected directly to the display. Another thing... is your display HDCP (copy protection) compliant? If not, the HDMI connection fails, and the player retries the HDMI handshake every few seconds.
Gary
post #362 of 364
Originally Posted by Neuromancer View Post
You can hack HDCP; you can't hack CSS-encryption removal (ie. component based upconversion).
Has there been any patches or hacks released for the DV-980H or more importantly DV-983H that allow for CSS-encryption removal (ie. component video scaling to 720p/1080i) since the last posts in this thread? It would seem if HDCP can be removed in the 983, there must be some way of removing the CSS-encryption. Any thoughts or leads?
post #363 of 364
Originally Posted by JavierS View Post
Neuromancer was right, the patcher also works with 983 firmware.
I used V 1.3 of the tool and applied the hack on firmware V 430 and tested on a non HDCP PC monitor and also with a VP50 inputting on a HDMI port and outputting analog component. The VP50 blocks analog out if HDCP is detected meaning there was no HDCP whatsoever.
Cheers.
Where do I find V 1.3 of the tool? The link in the OP of this thread gives me a file labeled V 1.2.
post #364 of 364
I came to this thread looking for a place to post an issue I'm having with my 970HD, and your question intrigued me... looking into it, I think it may have been a typo by the OP... I think he meant v1.2, because I could not find a v1.3 hack.
  Back to Forum: DVD Players (Standard Def)
