AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › 52" 1080p LCD
52" 1080p LCD
post #1 of 5
Good day,
I am looking for any feed back or opions on this particular display.
Planar 52" LCD - PD520
Specs from Planar web site (They also are making a 42" & 46") :
Signal Compatibility
Video Support: HDMI (High Definition Multimedia Interface) with HDCP (High definition Digital Content Protection) for encrypted digital video, Component and RGB HDTV (1080p, 1080i, 720p), Component and RGB EDTV (576p, 480p), Component, Composite and S-Video SDTV (576i, 480i, RGB SCART with adapter, NTSC/NTSC 4.43, PAL (B,G)/(D,K)/I/M/N
Computer Support: Digital and Analog up to 1920x1080 @ 60Hz, Macintosh®
Communication: IR remote, RS-232
Audio: TOS-Link optical audio out, L/R analog audio in/out 10W per channel amplification
Connectivity
(2) HDMI: HDMI 1.2 (High Definition Multimedia Interface) with HDCP (High Bandwidth Digital Content Protection)
(2) Component (RCA): HDTV, EDTV, SDTV
(2) Audio (2x L/R RCA): Component audio in
(1) S-PDIF: Digital audio out
(1) RGB (HD15): HDTV, Computer (VESA DDC2B Plug & Play Compatible), SW updates, RGB, Component
(1) Mini-Stereo: 3.5mm-Computer audio in
(1) S-Video: SDTV
(2) Composite: SDTV
(2) Audio (2xRCA): SDTV Audio in (1 S-Video or Composite)
(2) Analog Audio L/R: Audio out L/R +/- (10W per channel amplified)
(1) D-SUB 9-Pin: RS-232 Control
RJ-45: Control Input
Performance
Screen Size: 52.037" (132,17cm)
Technology: Deep Color TFT Active Matrix LCD
Surface: Anti-Glare, Hard Coated
Native Resolution: 1920 x 1080 (2,073,600 pixels)
Aspect Ratio: 16:9
LCD Response: 6.5ms (gray to gray)
Luminance (cd/m2): 500
Display Colors: 16.7 million, 24-bit True Color
Backlight: 60,000 hr MTBF
Contrast Ratio: 5000:1 (Dynamic Contrast) 1500:1 ANSI
Video Processing: Cortez-plus® LCD controller with 10-bit Genesis Faroudja DCDi Cinema processor with TrueLife Motion-Adaptive De-Interlacing, ACM-3D for rich color processing and noise reduction, 3D Intellicomb® for optimal image enhancement, Auto-cinema mode with 3:2/2:2 pull down, MPEG noise reduction
Viewing Angle: Horizontal: +/- 88° (176°); Vertical: +/- 88° (176°)
Image Adjustment: Gamma, Contrast, Color Temp, Brightness, Contrast, Sharpness, Backlight, RGB gain/offset
Pixel Arrangement: RGB Vertical Stripe
Pixel Pitch: 0.20(H) x 0.20(V)
Features
Picture Enhancement: 10-bit Faroujda DCDi Cinema with TrueLife MADI
PC Auto-lock: Yes
PIP/PBP/POP: HD in HD, Dynamic scaling, Video PIP over full screen graphics and video backgrounds, Graphics PIP over full screen graphics background, Picture-by-Picture window, PIP resizing, PIP positioning
Transparent OSD: Yes
Flesh Tone Correction: Yes
Multi-language OSD: Yes
Full Function Remote: Backlit IR remote with discrete code source keys
Wall Mount: Optional, VESA standard 200mm x 200mm
Table Top Stand: Low-profile stand included, removable
Power Indicator: Adjustable front LED
Speakers: Optional (not included)
Amplifier Power: 10 watts x 2
General
Dimensions: W: 49.96" (1269mm), H: 30.16" (766mm), D: 5.51" (140mm)
Weight: ~65.0 lbs (29.48kg) w/o tablestand
Wall Mount: 200 x 200mm VESA® FPMPMI
Operating Temperature: 41° F (5° C) - 113° F (45° C)
Operating Altitude: Sea Level - 9,800 Ft (3,000m)
Operating Humidity: 10% - 90% non-condensing
Universal Power Supply: 90V - 264V at 50-60Hz (auto-ranging)
Power Consumption: <220W
Stand-by Consumption: <2W
Specifications are subject to change without notice.
Please let me know what you think of this unit.
KT
post #2 of 5
MSRP $5,999 available May 2007
post #3 of 5
Yup that is what I have heard as well. I am wondering if anyone has any insight on the specs of this unit. I had a B/B boy tell me that TFT would be a "Major" problem and that his display would not come close to the XBR 3 - what do you think / say?
KT
post #4 of 5
Wait til someone gets one and the reviews come out.
This set probably won't be in too many stores.
There are a lot of good 52" LCD's for less than $5,999 MSRP.
(Sony, Sharp, Samsung.....)
post #5 of 5
I've had this set for about three weeks and have yet to do extensive calibration. But already, in my opinion, it is worth every cent. I do not know why they have not been professionally reviewed other than, perhaps, they are available through only a limited channel.
