AVS › AVS Forum › Display Devices › Rear Projection Units › Hitachi 51F59 questions
Hitachi 51F59 questions - Page 2
post #31 of 37
Originally Posted by lacombo View Post
Wish this thing had QAM, would def be a no brainer...
It's kind of lame that Hitachi chose not to add a QAM decoder; especially for those that don't want to use a STB.
post #32 of 37
Does this set have a first surface mirror?
post #33 of 37
According to this doc (a page from the service manual, compliments of Ballz2The Wallz), the 51F59 has a second surface mirror. The 57F59 has a first surface mirror.
post #34 of 37
Originally Posted by undercaution View Post
I want to know if you are able to store any equipment on top of this TV,as I have not seen one in person. Just a STB, and a DVD player is what
I would need, the deal on these tubes is just to good to pass up, I just
don't have the room for a rack if I buy one. If you can't store anything on
top I'll just go ahead keep up my research on the other TV's.
Thanks.........John
FYI: I have a 12# receiver, 8# center, and around 12# DVD/DTV on top of my 57F59
post #35 of 37
True, but lack of QAM kept the initial price down.
Actually that and the removal of the "HD tuner" (still does digital OTA, but only displays actual HD via component/HDMI inputs--OTA HD gets dumped to 480i then internally rescaled to 1080i)
Because of that, you could jump on the 51" for around $600 when CC/BB/etc were blowing them out.
For that price, you could easily afford an ext HD tuner or just suck it up and get a cable box (or HD Tivo or whatever with cablecard abilities).
Rather they make the cuts there than in the optics.
post #36 of 37
Nice lookin' pic, Gordon!
Have you done any of the "tweaks" to your set? Looks too good to be in OOB form.
post #37 of 37
Can this unit be removed from it's "base"?
HH Gregg has it at a great price. I would be running 3 Xls vertical in my HT system and could have a sturdy enough stand to have my center "under" the unit....
I've got a heavy wood piece I could set it on & "anchor" to the wall....
To replace this:
EDIT: nevermind. From user's manual PDF it looks like some of the boards/connections are part of the base. Bummer....
  Back to Forum: Rear Projection Units
