Here is a fast, consistent process to edit and prepare MPEG-2 transport streams (.ts files) to play on the PS3.
Benefits
* No video conversion; quality is identical to the original broadcast.
* Blu-ray media is not required; DVD is fine as long its capacity is not exceeded.
Caveats
* Multichannel audio is converted to stereo.
Software Required
* Windows XP
* VideoReDo Plus V2.5 for removing commercials.
http://www.videoredo.com/ (low cost, free trial)
* MPEG Streamclip for Windows V1.1 for audio conversion.
http://www.squared5.com/ (free)
* QuickTime Alternative 1.78 (MPEG support for Streamclip)
http://www.codecguide.com/download_qt.htm (free)
* GEAR Video 8.2 for burning DVD media.
http://www.gearsoftware.com/ (low cost, free trial)
Tested Configuration
* PS3 System Software Version 1.60
* Ritek DVD+R DL Media
Process Steps
1) Edit the original MPEG-2 transport stream (.ts file) with VideoRedo and remove any commercials and/or unwanted content. Save the video as a transport stream.
2) Open the video with MPEG Streamclip and covert it to a TS with MP2 audio. Streamclip will convert the AC3 3/2, 48 kHz, 384 kbps audio stream found in domestic ATSC transport streams to a Stereo, 48 kHz, 384 kbps, MPEG Layer 2 audio stream suitable for the PS3.
3) Rename the file extension from .ts to .m2t. This is very important. If you skip this step, the PS3 will not display any content. When you try to view the disc contents from the XMB, it will simply report "There are no titles."
4) Burn the .m2t file to a DVD with GEAR Video. Create a pure UDF 2.01 disc. You do not need to create any special folders, just place the .m2t file in the top level directory. My files have averaged approximately 4.6GB for a one hour program. Slightly too large for a single layer DVD.
If you view the file information from the XMB, it will display the correct file size, length, resolution, video codec and audio codec.
Due to what I consider to be a bug, the PS3 will only allow you to fast forward or rewind a very small portion of the program. Other than that, your files will play perfectly.
Enjoy!
Benefits
Caveats
Software Required
* Windows XP
Process Steps
Enjoy!
