Pat, just a quick note on the Philips 3576 or Magnavox H2160 (#1 link in my sig.).
You don't need a converter box for it cuz it has NTSC/ATSC/QAM tuners so it can tune all unscrambled channels from OTA or cable feeds. Basic System Connections are shown in sketch #1 here.
If you connect your analog Panny's to the coax passthru (output) of the Philips/Mag (the "other DVDR" shown in dotted lines in sketch #1), each analog DVDR will be able to tune its own channels, again if you're on cable. If OTA, your analog Pannys will need a converter box and only able to tune/record the channel the converter box is set on... using a line connection for best PQ.
One "odd" possibility is using the Philips/Mag as the digital converter box for one of the Pannys, as described here. This ties up both machines for one channel (in the Philips/Mag), but it's purpose might be for using the FR rec modes and more sophisticated editing of the Panny?
If you get a new HDTV with at least ATSC and QAM tuners, you won't need a converter box on the TV for either OTA or cable.
I'll let others who know more about the future of cable TV post on that subject.
